Go to Post The magic in a competition isn't finding creative ways to make an opponent lose, but finding even more creative ways for you to win. - galewind [more]
Unread 17-11-2002, 19:52
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
Originally posted by SuperDanman
Thanks for all this, but a lot of it I got from the "Power, speed, and torque... AGH" thread. My question still stands - exactly why does the back EMF sink the input voltage? Is EMF a voltage that travels the opposite direction the incoming voltage travels, or is it just a force that reduces the pressure of the incoming voltage? If the latter, then I don't see the relationship between this force and the voltage. I basically need some help on the physics of the EMF.
The easiest way for me to think of it is as follows:
Current (I) = Voltage(V)/Resistance(R)
using this formual, we can get the following:
I = (Vbattery - Kv*Ang)/(Rbattery + Rmotor)
where:
I = current
Vbattery = battery voltage
Kv = motor's velocity constant - (rad/s)/V
Ang= motor's angular-velocity (rad/s)
Rbattery = battery's internal resistance + wiring or speed controller resistance
Rmotor = motor's armature resistance
from this, we can see that since the battery voltage will be 12V, once the RPM reaches a certain speed the top part of the equation, the (Vbattery - Kv*Ang) will be negative. This will make the current negative. the sign of the current tells which way the current is flowing. If the current is negative it means the motor is generating more voltage than the battery, which causes the current flow to reverse direction and the battery will start to be charged, instead of drained.
Thats the only way i understand it, the EMF stuff was jibberish to me too
Tom
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
