| It's EASY to C why I PROfess my love to you! |
#16
Re: Robot Inspection Checklist Prior to Matches
To comply with R69, our air compressor is onboard our robot, and used while in play. The only difference is we fill our tanks from an external battery before matches. We then place the robot battery on, take away the old ones, and are left with a completely legal robot, starting off with full tanks of air. It's 100% legal.
THE SUBJECT OF THIS THREAD WAS ASKING FOR OBJECTS ON AN INSPECTION LIST, NOT A DEBATE ON WHETHER OR NOT PRE-PUMPED AIR TANKS ARE ALLOWED. PLEASE EITHER STOP THE DEBATE OR MAKE A NEW THREAD FOR THIS. Thank You. |
#17
Check to see if things that could be loose are loose (if that made sense)
i.e. we have "licorice" or whatever you'd like to call it as intake, so we test that, as well as the tread on the tires, etc. |
#18
Our team makes (and iterates) custom pit & drive team lists every season, starting with what we notice is temperamental during build & pre-ship practice. It's saved us a lot of "do'h!" moments and definitely helps keep maintenance under control. Here's this year's.
#19
Regarding pre-pressurizing, I suggest reading these threads:
http://www.chiefdelphi.com/forums/sh...ght=compressor http://www.chiefdelphi.com/forums/sh...ght=compressor I believe the net is that using a second battery or even a second compressor is not permitted. John Vriezen Team 2530 "Inconceivable" Mentor, Drive coach, Inspector |
#21
Can anyone find a rule that states the pressurized air in the robot at the start of the match must have been supplied by the exact same battery used to run the robot for that match? I don't think there is one. |
#22
I quite disagree.
There is no such rule. The match begins on the field when the robot is turned on, not in some imaginary place like the pit or the queue. (or in a previous match if pressure is left over) Quote:
#23
EDIT: Upon checking the rules, I retract my statement. Last edited by scottydoh : 30-03-2011 at 13:56. |
#24
We pre-charged our pneumatics during the San Antonio Regional. I described exactly what we were doing (and in what order) to the inspector (since we had never left the pump off before) and he said we were in compliance. It is hard to believe it is against the rules to change to a fresh battery after charging pneumatics, testing the robot, pre-positioning arms etc. What purpose would such a rule serve?
#25
I'm certain you won't find that written anywhere official. The rules are clear: the compressor must be controlled and powered by the ROBOT, not by an external system.
#26
I'm sorry, did I say my answer was official?
#27
We always try to have a checklist but this year it has actually been used every match because we put it on the back side of a piece of lexan on the robot and check it off with a dry-erase prior to each match. This allows us to have it on the field where stuff like turn it on and remove safety pin comes into play.
#28
Our team has a checklist as well. We print off several copies then check off every item on it before each of our matches. Always make sure that everything is plugged in right on the electrical board. Sometimes one thing out of line here can make the entire robot stop working. We usually test our drive train before each match too, just to be sure that if all else fails our bot still has defensive capability.
#30
Our team has learned the hard way at the Week Zero and thursday at GSR, make sure every pnuematic end is closed.
