Go to Post Cant get hair and nails done and still run a robot. - wendymom [more]
Unread 30-03-2011, 07:26
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Using Second battery to Charge Tanks
Use battery one to charge the robot up, making sure that it is the robot controlling the compressor, not just hard wired or an external switch.
Turn robot off.
Remove battery and replace with a fresh battery two.
Go to field and compete.
Unread 30-03-2011, 11:39
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Turn robot off.
I understand that's how it's done, but is it legal?
A robot is one compressor and 1 battery. By using two batteries you are effectively using more "electrical energy" than is available in one battery. This is what I am questioning.
When I was asking about off board compression, I was told we had to use the same battery as we would use in the match. Why is keeping the compressor on the robot given an exemption to that rule?
Unread 30-03-2011, 12:08
I assume you asked the GDC in a Q&A not some random volunteer.
Remember, even answers from the Lead Robot Inspector may change as the season progresses and they all come to a common rules interpretation.
I don't recall any such Q&A though.
I think your issue here is how the question is framed and (presumably answered by the GDC).
The answer you received appears to simply be addressing the issue that the compressor must be powered through the robot by the robot battery whenever it is operated, not that batteries cannot be changed.
The robot can only be powered by a single battery while in a match.
A match doesn't begin in the pit or on the queue or in a previous on-field appearance where pressure wasn't releaved afterwards.
A match begins when the field sounds.
Unread 30-03-2011, 12:21
wilsonmw04's Avatar
Coach
The answer you received appears to simply be addressing the issue that the compressor must be powered through the robot by the robot battery whenever it is operated.
And that is the question I think is core to my problem. When does the robot become the robot?
From my POV once you use the battery to compress air in your tanks, that battery becomes part of the robot for that match. If you removed the battery after the compression, you are using two batteries for a match.
Mark,
The question regarding swapping batteries was asked in the Q & A and they directed the petitioner to R69. I'm just not sure how that answers the question.
Unread 30-03-2011, 12:24
Then I posit that you cannot change your battery after you have used the energy to download any code that will be used in said match.
Unread 30-03-2011, 12:35
wilsonmw04's Avatar
Coach
I would disagree because changing code does not store anything that could do work for the robot.
Thanks for being lighthearted about this. This is not a hypothetical for my team. With such a large set of tanks this year, it take over one minute to charge our system. If we could do that with another battery it could be a substantial advantage for the team. I just don't see how it jives with the rules. I know others do it; the GDC is rather vague on the issue. I just don't like gray areas. It get's folk in trouble and feelings hurt.
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Probably should just use the same battery you used to image the cRIO last.
Unread 30-03-2011, 12:44
I don't believe any rule supports your self-imposed position.
I don't beleve the GDC supports your position, otherwise, they would say so.
I believe only one battery can be used during a match.
A match begins with the field sound and ends with the refs all clear flag.
(it doesn't end with a field sound this season).
I don't accept the stored energy argument (even without the evidence of a rule), otherwise, springs, elastic tubing and other potential energy storage is also suspect. Thereby excluding human muscle power from the robot, as well, if the battery is the sole source of energy.
My beliefs don't constrain the GDC, but are what I will advise any team that asks.
I'm rooting for your students.
Unread 30-03-2011, 12:49
wilsonmw04's Avatar
Coach
As am I. They are a great group of kids.
Dude, just saw you'll be at VCU in a week. I'll look you up. It will be nice to match a face to a CD tag.
Unread 30-03-2011, 13:01
Your honorable stance teaches them all they need to know to have a successful and fulfilling life.
I'm a mentor with team 2402 from Fredericksburg. I'm older than my photo appears (my hair is graying now) -that was taken more than 10 years ago.
I get around...
Go Rams!
Unread 30-03-2011, 13:58
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
So... has anyone come to a conclusion on this issue?
It is very clear that the robot must be controlling the compressor when it is filling the tanks - on board or not.
There is a very interesting question regarding switching the battery after the compression is complete. For many robots this is not a real "game changer", but at least one example that's been mentioned on these forums is a robot that requires 7 minutes to compress its tanks!
This is roughly about 40% of the total energy output from the battery in the duration of a match.
Yes, it is legal to store this much energy in springs on the robot, but there is no rule saying that "springs must be stretched/compressed under the control of the ROBOT".
It seems to me that the answer to this question could indeed be a "game changer" in certain circumstances.
When does a robot become the ROBOT?
-Mr. Van
Coach, Robodox
Unread 30-03-2011, 14:53
To have the force of a rule there must be a clear interpretation from the GDC and uniform "enforcement" across all events. That's the rule "rule."
I don't mean "enforcement" in the sense that an authority such as the Lead Inspector must stand over us. It's on the honor system. We all want to do the right thing.
I just mean that the event authority (and in this case it would be the Lead Robot Inspector's responsibility) makes it clear that's how the rule will be read.
Since, teams have done this for year's under essentially the same rule set, I think it's a stretch to say this is a rule, much less a uniform interpretation.
From their Q&A response and actions, or lack thereof, I don't believe that the GDC agrees with this particular interpretation.
The Q&A response seemed to be that there was obviously no such rule limiting when the battery can be changed.
I think we are all leaving with the same interpretation that we came in with...
There is no way to prove an anti-rule.
Unread 30-03-2011, 14:58
Do teams with onboard compressors vent their pneumatic system every time they change batteries?
Unread 30-03-2011, 18:57
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
I get around...
Go Rams!
He's lying, his hair isn't graying, its gray
I believe the intention of the ruling is to make sure the pneumatics are charged and controlled under the same rules and conditions (and safety systems) any other robot with the compressor on-board would have. This makes sense, and while cumbersome, I can understand it.
However I fail to see any way in which using a separate 'practice' robot battery bypasses any of those particular intended restrictions, or otherwise gives you an advantage or presents a danger, and thus I would have interpreted the ruling to allow you to swap your battery between charging the pneumatics and competing on the field.
That said, I'm only me, and my name isn't nearly popular enough to sway inspectors or refs ask the GDC for this exact situation. I believe they will rule in your favor, but having it confirmed can help everyone rest easier.
Matt
Matt Krass
Unread 30-03-2011, 19:47
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Originally Posted by Matt Krass View Post
I believe they will rule in your favor...
Famous last words?
