Go to Post Safety is everyone's job. - Wetzel [more]
Unread 30-03-2011, 00:08
Andrew Lawrence
Posts: n/a
Re: Robot Inspection Checklist Prior to Matches
To comply with R69, our air compressor is onboard our robot, and used while in play. The only difference is we fill our tanks from an external battery before matches. We then place the robot battery on, take away the old ones, and are left with a completely legal robot, starting off with full tanks of air. It's 100% legal.
THE SUBJECT OF THIS THREAD WAS ASKING FOR OBJECTS ON AN INSPECTION LIST, NOT A DEBATE ON WHETHER OR NOT PRE-PUMPED AIR TANKS ARE ALLOWED. PLEASE EITHER STOP THE DEBATE OR MAKE A NEW THREAD FOR THIS. Thank You.
Unread 30-03-2011, 00:15
lightsandmusik's Avatar
lightsandmusik lightsandmusik is offline
little girl?
AKA: Karen Izumoto
lightsandmusik has a spectacular aura aboutlightsandmusik has a spectacular aura aboutlightsandmusik has a spectacular aura about
Check to see if things that could be loose are loose (if that made sense)
i.e. we have "licorice" or whatever you'd like to call it as intake, so we test that, as well as the tread on the tires, etc.
100 100 110! What does that spell?
-mumblegrumble- nothing. it's a bunch of stupid numbers
Unread 30-03-2011, 00:16
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Our team makes (and iterates) custom pit & drive team lists every season, starting with what we notice is temperamental during build & pre-ship practice. It's saved us a lot of "do'h!" moments and definitely helps keep maintenance under control. Here's this year's.
Unread 30-03-2011, 00:30
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Yes, the majority of a list like this will be robot specific. On 2175 it is known as the "Stupid" List because you feel real stupid when you lose a match because you didn't check something on it.
Unread 30-03-2011, 09:20
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Regarding pre-pressurizing, I suggest reading these threads:
http://www.chiefdelphi.com/forums/sh...ght=compressor
I believe the net is that using a second battery or even a second compressor is not permitted.
John Vriezen
Team 2530 "Inconceivable"
Mentor, Drive coach, Inspector
Unread 30-03-2011, 09:57
Using an additional battery or compressor is pretty clearly against the rules. I'm not so sure about the practice of swapping batteries between precharging the pneumatic system and running the match. You're never using more than one battery to run anything, so you don't run afoul of the rule requiring only one battery.
Can anyone find a rule that states the pressurized air in the robot at the start of the match must have been supplied by the exact same battery used to run the robot for that match? I don't think there is one.
Unread 30-03-2011, 10:47
I quite disagree.
There is no such rule.
The match begins on the field when the robot is turned on, not in some imaginary place like the pit or the queue.
(or in a previous match if pressure is left over)
Originally Posted by wilsonmw04 View Post
I would take a position that what they are doing would affect the robot while on the field and there would be illegal. So you don't see this as using two batteries during a match: one to charge the system and another to run the robot and the compressor to keep the system charged?
Please defend that position. Seems cut and dry to me.
Unread 30-03-2011, 11:34
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
I don't believe it says it directly in the rules, but I remember seeing somewhere that as long as you have a complete second system (battery, CRio, pressure switch, etc.) that is in fact legal. But stand by, I'm looking for a source now...
EDIT: Upon checking the rules, I retract my statement.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 30-03-2011, 11:56
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
We pre-charged our pneumatics during the San Antonio Regional. I described exactly what we were doing (and in what order) to the inspector (since we had never left the pump off before) and he said we were in compliance. It is hard to believe it is against the rules to change to a fresh battery after charging pneumatics, testing the robot, pre-positioning arms etc. What purpose would such a rule serve?
Unread 30-03-2011, 13:08
I'm certain you won't find that written anywhere official. The rules are clear: the compressor must be controlled and powered by the ROBOT, not by an external system.
Unread 30-03-2011, 13:52
AKA: Scott
I'm sorry, did I say my answer was official?
Unread 30-03-2011, 14:12
Mike dennis's Avatar
Mike dennis Mike dennis is offline
SPAM (2009-2013)
FRC #1902 (Exploding Bacon)
Mike dennis is a jewel in the roughMike dennis is a jewel in the roughMike dennis is a jewel in the rough
We always try to have a checklist but this year it has actually been used every match because we put it on the back side of a piece of lexan on the robot and check it off with a dry-erase prior to each match. This allows us to have it on the field where stuff like turn it on and remove safety pin comes into play.
Unread 30-03-2011, 14:16
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
That is a really really good idea.
Unread 08-04-2011, 01:24
fyrefrost fyrefrost is offline
FRC #1245
fyrefrost is an unknown quantity at this point
Our team has a checklist as well. We print off several copies then check off every item on it before each of our matches. Always make sure that everything is plugged in right on the electrical board. Sometimes one thing out of line here can make the entire robot stop working. We usually test our drive train before each match too, just to be sure that if all else fails our bot still has defensive capability.
Unread 08-04-2011, 01:41
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Our team has learned the hard way at the Week Zero and thursday at GSR, make sure every pnuematic end is closed.
1058 PVC Pirates 2016 - xxxx
