Go to Post Cue all the jokes about natural selection in the Darwin division - TDav540 [more]
Unread 30-03-2011, 11:34
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Robot Inspection Checklist Prior to Matches
Originally Posted by Alan Anderson View Post
Using an additional battery or compressor is pretty clearly against the rules. I'm not so sure about the practice of swapping batteries between precharging the pneumatic system and running the match. You're never using more than one battery to run anything, so you don't run afoul of the rule requiring only one battery.
Can anyone find a rule that states the pressurized air in the robot at the start of the match must have been supplied by the exact same battery used to run the robot for that match? I don't think there is one.
I don't believe it says it directly in the rules, but I remember seeing somewhere that as long as you have a complete second system (battery, CRio, pressure switch, etc.) that is in fact legal. But stand by, I'm looking for a source now...
EDIT: Upon checking the rules, I retract my statement.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
