Go to Post however, if i tried it i would probably end up setting my hair on fire - Henry_Mareck [more]
Unread 28-03-2011, 01:53
AlDee AlDee is offline
FRC #1099
AlDee is an unknown quantity at this point
Light Switches on Minibot
The approved parts list for the minibot says you may use no more than 2 standard light switches. Does anyone know if this includes "2-way" light switches. I'd like to be able to switch a wire from one connection to another using a single switch if I can.
Thanks,
--Al
Unread 28-03-2011, 02:16
chmconkling's Avatar
chmconkling chmconkling is offline
Jack of all groups. Master at most.
AKA: chris
FRC #2363 (Triple Helix)
chmconkling is an unknown quantity at this point
Re: Light Switches on Minibot
that rule inculdes all light swtiches used in the home we have a 3 way light switch on our minibot
Unread 30-03-2011, 01:06
FRC #1099
Well that simplifies things quite a bit. So I take it then that a decorator push button or rocker type switch woul be ok?
Unread 30-03-2011, 01:09
FRC #1099
On a similar note, can the switches be drilled to have a screw through the handle to have more reach?
Thanks,
--Al
Unread 30-03-2011, 01:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Thanks,
--Al
Yes, there are no rules that prevent such modification.
Unread 30-03-2011, 09:57
The Lucas's Avatar
CaMOElot, it is a silly place
Make sure you bring documentation that indicates that switch is being marketed as a "light switch" to show the inspector. The light switch does not have to fit in a wall box, just marketed as a "light switch" for household use. Refer to TU12
Robot Inspector
Unread 30-03-2011, 12:21
tdramble tdramble is offline
FRC #1014 (Bad Robots)
tdramble will become famous soon enough
We used a common limit switch that comes in the kit of parts and bent the long metal piece around itself so when it gets pushed down, it stays down. So when the minibot reaches the top, the switch get's hit, the battery is removed from the circuit, a new circuit is completed that shorts the terminals on the motors so the minibot comes down nice and slow.
