Go to Post If it's not on fire, it's a software problem. - Matt Leese [more]
Unread 30-03-2011, 19:19
siggy2xc siggy2xc is offline
AKA: Tyler Siegrist
FRC #1756 (Argos)
siggy2xc is an unknown quantity at this point
Increase a value using a joystick
I want to increase a value over time when using the joystick. The value would start out at zero and you would press the joystick forward, the longer you press it forward the larger the value gets and when you hold the joystick down the value gets smaller over time.
Unread 30-03-2011, 19:24
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Increase a value using a joystick
I'd have a feedback node/shift register storing the current value, and each iteration the value of the joystick adds to it. It'd probably be a good idea to make a separate loop in periodic tasks so that you get a constant rate.
What are you using this for?
Unread 30-03-2011, 19:27
I think you are looking for a "shift register". It is a node that remembers the last thing that you wrote to it.
This can be found on the Programming -> Structures palette. It looks like an arrow in a rectangle. It can point in either direction (right click to change). New data goes into the tail of the arrow, old data comes out the tip of it.
Unread 30-03-2011, 19:37
AKA: Tyler Siegrist
FRC #1756 (Argos)
In simplest terms, I'm trying to move a point on a graph using the joystick. I can get it to increase and decrease, i just need to make it so that it is not so rapid. Would i just put a wait timer in there or would that slow down the code?
Unread 30-03-2011, 19:41
A wait timer would slow down Teleop, but would work fine in Periodic Tasks.
Anything you can do in Teleop, you can also do in Periodic Tasks if you need explicit delays.
Unread 30-03-2011, 19:50
AKA: Tyler Siegrist
FRC #1756 (Argos)
This isn't part of the robot project. This is just a simulator
Unread 30-03-2011, 19:54
AKA: Tyler Siegrist
FRC #1756 (Argos)
Would i just have the values writing in a separate while loop with a wait timer in it?
Unread 30-03-2011, 19:55
Lets say you hold the joystick full forward "forever". What do you want the output to be? Should it keep going up, or settle to match the joystick's position?
Unread 30-03-2011, 19:56
AKA: Tyler Siegrist
FRC #1756 (Argos)
keep going up
Unread 30-03-2011, 20:33
A separate, independent while loop that constantly checks the joystick at the rate you decide upon would work.
Unread 30-03-2011, 23:46
WizenedEE's Avatar
AKA: Adam
Or if you want to be fancy, you could have it update the value every so often, while still running the loop.
Better still, have it update the value every iteration, but have something that reads the speed of the loop and divides the value of the joystick by a number proportional to that.
Or just add the timer...
You should have the program generate a maze, plot it on an XY graph, and then use the joystick to navigate the maze. That would be epic.
Unread 30-03-2011, 23:57
AKA: Tyler Siegrist
FRC #1756 (Argos)
I like your ideas WizenedEE! but I'm just trying to simulate a robot drive (which is a lot easier than I originally thought!). That maze project sounds like some good practice
