Re: Increase a value using a joystick
Lets say you hold the joystick full forward "forever". What do you want the output to be? Should it keep going up, or settle to match the joystick's position?
keep going up
A separate, independent while loop that constantly checks the joystick at the rate you decide upon would work.
Or if you want to be fancy, you could have it update the value every so often, while still running the loop.
Better still, have it update the value every iteration, but have something that reads the speed of the loop and divides the value of the joystick by a number proportional to that. Or just add the timer... You should have the program generate a maze, plot it on an XY graph, and then use the joystick to navigate the maze. That would be epic. |
I like your ideas WizenedEE! but I'm just trying to simulate a robot drive (which is a lot easier than I originally thought!). That maze project sounds like some good practice
