Go to Post if you want FIRST people to sign a petition, July isn't the best time to do it. - Pault [more]
Unread 31-03-2011, 13:39
Re: servo jitter when running Jaguar on RS-775
I am going to throw a guess on this one where the Jag breaker isolates it and switching PWM servo outputs moves the problem. The Jag is capable of very high rise times and therefore is likely to put some wild RF signals on the motor leads. If the 775 has a case short, caps across the motor leads will not help. I have experienced noise currents traveling on wire and then crossing over to another wire and causing problems. Sometimes, RF ferrite beads around the conductors can shunt the noise. My suspicion on the 775 problem is that you will find it to be a greater problem when driving in one direction vs. the other. If that is indeed the case, then there are significant currents driving through the case to the common electrical lead on the Jag and back out to anything connected to the Jag with the same common terminal.
Unread 31-03-2011, 20:19
Brandon Holley's Avatar
Your guess seems right to me. Our servos only showed the issue when the elevator was driving up (aka: under the largest load).
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 01-04-2011, 07:34
Gdeaver Gdeaver is online now
FRC #1640
Has any one tried adding a cap to the servo wire as close to the servo as possible? While it may not work in this case, It has solved twitchy servo problems on some of my projects in the past. Cap on the + and - .
Unread 11-05-2011, 09:38
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
I've taken of the RS775. It did indeed have a short to its case. (About 1 ohm)
There was nothing else connected to the frame, but considering the long servo runs, I don't doubt that the servos were jittering from induction onto their signal line.
I'll get around to testing sometime.
-- Marshal Horn
