Go to Post Doing something reliably is better than doing something well occasionally. - Andrew Schreiber [more]
Unread 31-03-2011, 23:32
Hjelstrom's Avatar
Hjelstrom Hjelstrom is offline
FRC #0987 (High Rollers)
Hjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond repute
Reading Driver Station Input to select Autonomous Routine
In past years, we had a little piece of code that was in our 'Disabled()' function which read some switches on our driver station to select an autonomous routine (basically set a variable to the number of the selected routine). This year we can't seem to get that to work at "real" fields. It works fine when we're testing but when we're hooked up to the field, the code within Disabled() never seems to get run before the match starts and we don't end up running the auto routine we intended to.
Someone said it should be ok to read the switches within our "Autonomous()" function but that seems to always give us all zeros.
For now, we're just hard coding our selection and deploying new code but it would be nice to get the switches working again. Any ideas?
Unread 31-03-2011, 23:52
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Reading Driver Station Input to select Autonomous Routine
Did you try wrapping a if (IsDisabled()) {} around the switch checking code in Disabled() so it doesn't get zeroed out on the last run as it transitions into auto. It sounds like you are using SimpleTemplate, correct?
Good luck at Las Vegas
Robot Inspector
Unread 01-04-2011, 00:58
Hjelstrom's Avatar
Thats a great idea. Thanks!
Unread 01-04-2011, 09:49
Hjelstrom's Avatar
Hmm, that can't be it because once we read a non-zero value, we ignore zero (the code won't over-write the sequence number with zero). We'll try some more things today and I'll report if we figure something out, maybe there's a mistake that we're missing.
Unread 01-04-2011, 10:03
The Lucas's Avatar
are you reading digital switches or analog values? Ignoring a zero value on a digital switch is generally a problem, maybe post a code snippet?
Robot Inspector
Unread 01-04-2011, 10:42
Jared Russell's Avatar
Taking a year (mostly) off
Have you tested your code with the "Practice" option in the Driver Station? This function walks through the Disabled/Autonomous/Teleop states in a manner that is supposedly identical to FMS'.
Unread 01-04-2011, 11:49
I worked with 987 a little on this issue in San Diego, but not having used the cypress or C++ before, we weren't able to figure it out.
They're using a rotary switch, I think it was 16 positions. They would only be ignoring the all switches 0 condition.
They did run it in practice mode, and it worked.
987, did you ever get a chance to try it with the virtual I/O?
Unread 01-04-2011, 14:16
The Lucas's Avatar
Had it working with Cypress and C++ last year (only difference is we essentially use IterativeRobot Template). We eventually stopped using the Cypress because it is unreliable when the Classmate is not plugged in (it doesn't always get the required power).
Robot Inspector
Unread 03-04-2011, 10:00
Hjelstrom's Avatar
We're using a rotary switch which is just like 4 dip switches. Using 4 bits you get a number from 0-15. We normally call this in "Disabled()". In 'practice' mode it works, we can run different auto sequences at will but we always switch the robot to 'Disabled', then line it up, then 'Enable' again.
Here is the code to read the switch. I do see a logic/comment flaw in that if the inputs were really all zero, then the seq number would be 15 not zero. So maybe in auto the inputs are all pulled high? I recall in previous years, if you ran code like this during auto, you'd always get zero back as the desired sequence.
We're using 'SimpleRobot' and this function is called from 'Disabled()'
	void Read_Auto_Switch(void)
		// Check the auto sequence number only in disabled mode!  During auto, all
		// DS inputs are zeroed.
		int seq = 0;
		bool Dec1 = !ds->GetDigitalIn(1);
		bool Dec2 = !ds->GetDigitalIn(3);
		bool Dec4 = !ds->GetDigitalIn(5);
		bool Dec8 = !ds->GetDigitalIn(7);
		if (Dec1 == true)
			seq += 1;
		if (Dec2 == true)
			seq += 2;
		if (Dec4 == true)
			seq += 4;
		if (Dec8 == true)
			seq += 8;
		if (seq != 0) AutoSeq = seq;
In our constructor, we have "ds = DriverStation::GetInstance();"
With a little experimentation, I think we could have sorted out what was going on yesterday but the auto is working so well we decided not to touch anything! :-)
Unread 03-04-2011, 11:22
The Lucas's Avatar
int seq = 0;
You are inverting all the switches when you get them (bool Dec1 = !ds->GetDigitalIn(1) so it makes sense that the the seq goes to 15 in auto. So in auto all the GetDigitalIn() calls return false then they are inverted to true and stored in Dec1-8. I am not sure exactly how your rotary is wired that you needed to invert the inputs (I imagine it is grounding one input at a time). In the past (we dont use the Cypress this year) we have used a rotary switch and soldered resistors between adjacent positions to make a variable voltage divider then read it in as an analog value check to see if it is in different ranges.
Wrapping an IsDisabled() around this function as suggested before would work (stop AutoSeq being set to 15). You can also check that (seq != 15) before setting AutoSeq.
Also a CD posting tip for the future: there are code tag that you can wrap around posted code to preserve the indentation and make it easier to read. You just need to press the # icon on top of the post box to put code tags in your post. Code tags also work well for tab spaced tables (like one you might copy from Excel)
Auto going well, that is an understatement. Great job on that consistent 2 uber tube auto! Are you checking the lines at times for alignment? It is truly unique set up for 2 tube with you starting at the Y and going across the other robot to get the tube at the other line.
I watched the impressive LV archive you guys set up. Congrats on your first 2 regional win season!
Robot Inspector
Unread 03-04-2011, 16:22
Hjelstrom's Avatar
Sorry, I haven't conveyed exactly whats going on as well as I should. That code generates seq=0 when in autonomous. So that would imply to me that all of the switches read 1 during auto making the comment in the code incorrect. (thanks for the code tag idea too, I'll try to go back and edit that)
When I get time with the robot again, I'll look over the wiring and do some experiments to re-test the assumptions we're making. If I recall correctly the switch is wired to simply connect the digital inputs to ground so we're assuming there are pullup resistors on the DS board. That would be consistent with reading all 1's and also consistent with the way the code is inverting each bit before adding everything up.
Thanks very much for your brain cycles! It was a pleasure working with 365 a couple of years ago in Atlanta! You guys have a terrific team.
We do use the line sensor and encoders to know when to move to the next state. Thanks for the compliments. My son (8th grade) wrote most of the code for the robot. He's really picking up programming; he's already published an indie xbox 360 game too (its named "Phat Fly" if you want to look it up).
