Re: Arduino and LabVIEW
Well we are talking about an Arduino.
But no, just a signal to change lights.Howsoever, I did see at FLR a team using an Arduino for sonar processing, but I don't know what kind of data they were sending back to the cRIO -- much more than I'm asking for, I'm sure. These little boards are fun to work with. |
An update -- I have some LabVIEW code that sends a DIO true/false value depending on a button press, recieved by the Arduino on a digital pin, and blinks the light on the Arduino and also prints out the high/low value (simple test), slowed down to 1/2 second cycle. Currently I'm getting a semi-random highs/lows, even without pressing the button, which I'm guessing is LV's issue, not continually sending the true/false signal? Unfortunately, I lost my LV computer so I can't check it -- maybe I can schedule for a 3 am session?
If you haven't opened the IO port in your code, I think it may leave the signal pin floating. Does it work when you press the button, or does it ignore the button as well?
I think it's opened once in the Begin.vi (the computer got grabbed so I can't look at the code at the moment), and just referenced during the button pressing, and not open/send/closed each time.
There was no discernable difference when the button got pressed. |
Consider the fact that a boolean on the PPC is 4 bytes. Also consider the fact that the Arduino uses little endianness. I am not sure about the PPC on the cRio, it might be a big endian, that might bring up some troubles.
#7
But aren't they both using an on/off electical signal to talk between them? Not code.
(Pay Per Click?) |
#8
So on the cRio a "true" would be represented as: 0000_0000_0000_0001B (if big endian) 0001_0000_0000_0000B (If little endian) Note: I might be wrong about the above regarding the binary on the Arduino, you need to just take the last 4 bits so it becomes: 0001B Every microprocessors have millions and billions of transistors, they all use electrical signals. Now, if there are any veterans here, feel free to rebuke me. I am a student, I make mistakes and then learn from them. Last edited by davidthefat : 02-04-2011 at 23:11. |
#9
Setting a TRUE output on a DIO slot sends 5V of power down the wire. That's one bit, not 32. He's planning on using four DIO slots to send 4 bits of data to the arduino.
Just a note, you can put the PWM cable in sideways on the signal so you use two cables instead of four. Can you put a multimeter on the slots? Can you post the arduino sketch? |
#10
It was this that got a train of thought starting:
I had scribbled the Arduino and LabVIEW code in bed last night, and got half way thru it by the time I got back to the robot, but my lead programmer had different ideas (a piddly 16 numbers - pft! ), so we went his way. Still haven't tested that it really works, either way. |
#12
Watch this video, note why he uses the resistor. If you get it, good, otherwise, I'll explain: Originally Posted by Roger But aren't they both using an on/off electical signal to talk between them? Not code. Yes and no. The cRIO will send out an on/off electrical signal, but the Arduino DIO pin does not "sense" "on or off." It senses 5v or Ground. If you hook it up to nothing (what you may call "off"), it will basically sense the voltage of the wire/air that it is connected to. Ever looked at a volt meter when you haven't yet hooked it up to a power source? It wanders all over the place. This is what your Arduino DIO pin is doing. It could be anything, high or low. You need to use a resistor to specifically connect the DIO pin to Ground when it isn't sensing a 5v from the cRIO DIO pin. This is called using a pull-down resistor (not to be confused with a pull-up resistor, but similar idea). Do you have a mentor who is an electrical engineer or knows electronics? You should have him help you out. This concept is a little tricky, it took me a while to figure out. Before that I was thinking the same as you. Last edited by RoboMaster : 03-04-2011 at 01:35. |
#13
I'm pretty sure the DIO ports on the C RIO are never left floating (at the very least not after they're initialized), so that doesn't make much sense. There's nothing in the datasheet about it, strangely enough, except that there's a 10K pullup already on it. Maybe that's not disconnected when it switches to output? That wouldn't make much sense though.
I'd say test continuity, and then go to voltage mode on your multimeter, and do one lead on ground and the other on the signal. If you get zero, put the first on 5V. If they're both zero, the pin in floating for whatever reason, if one is zero and the other is 5V, then it's something in the wiring/arduino. |
#14
(Sorry, I went home and slept a bit.) Here's the Arduino sketch:
int ledPin = 13; // LED connected to digital pin 13
int inPin = 7; // pwm white wire connected to digital pin 7
int val = 0; // variable to store the read value
void setup()
pinMode(ledPin, OUTPUT); // sets the digital pin 13 as output
pinMode(inPin, INPUT); // sets the digital pin 7 as input
Serial.begin(9600); //Added this, seems to allow the prints to print
void loop()
val = digitalRead(inPin); // read the input pin
digitalWrite(ledPin, val); // sets the LED to the button's value
Serial.println(val); // print out the 1 or 0
delay(500); // Added 1/2 second delay just to slow down the prints
On the LabVIEW side there is code that if (one of 4) buttons are pressed, send a True/False to DIO Out Set (WPI_DigitalOutputSetValue.vi). I hold the button down to test, not momentarily. Currently (with the delay) the print sends "1100000111000011000001100" with or without the button presses, and there is no pattern to the length of the 1 or 0 groups. Without the delay it was all 1s. I also used the built-in LED on 13 to see if it's on or off. RoboMaster: I have the book version of that video (that's how I got my first Arduino). I'm not ashamed to say I'm not electrical-minded, but I know enough to keep me out of too much trouble. For this project originally I used the button setup to control the Arduino switching the LEDs. I've wondered about that resistor. This would be a simple test: Put the wire on a breadboard, split it with a resistor to ground, and a wire to Arduino's pin 7. I did understand David's answer (I think I did; hanging around teens I get that a lot), and I was answering more of a programming mode than electrically. WizenedEE: Maybe in the "robot world" the DIO ports aren't left floating, but when the wire is jumping into "Arduino world", would it need it's own de-floater resistor? I'm guessing at this. I do have a sensors/electrical mentor; he probably knows every wire on the robot on a first-name basis. He can test the wires to make sure they are what they ought to be. Sigh. Electricity was so much simpler when I grew up, when power went from + to - and not both ways. ![]() |
#15
Okay, back at the ranch... I tried with and without a resistor (10K and 1K -- that's okay? It's all I had). Signal from DIO connected to the Arduino 7 pin and also to a resistor to Arduino ground. I hope I got that right? I also took the delay out. With a resistor, it's always zero. Without, the Low/High is
11111100000000 11111100000000 11111100000000 11111100000000 11111111000000 11111111000000 11111111000000 11111111000000 1111111100000000 11111100000000 11111100000000 11111100000000 11111100000000 11111111000000 11111111000000 11111111000000 11111111000000 1111111100000000 11111100000000 11111100000000 11111100000000 11111100000000 11111111000000 11111111000000 11111111000000 11111111000000 1111111100000000 |
