Go to Post .. if everybody else is buying all the thingamabobs so they can practice shoving balls into the whatsit. Maybe what you really want is to buy thingys so you can build a practice whojidingle. Being the only whojidingle robot can be a real advantage come alliance picking time ... - ChrisH [more]
Unread 02-04-2011, 22:18
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Switching Drive System While Driving
Odd question but can you change the drive system as you are diving?
something like this:
if(joystick1.GetRawButton(2)){
myrobot.Tankdrive(joystick1.GetY(), joystick2.GetY());
Im asking this because today at our competition our drive didnt want to use menanume drive during parts of the match so i comments out the old drive system and then he wanted mecaume again and it was quite annoying
Any ideas?
Unread 02-04-2011, 22:20
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Switching Drive System While Driving
If you are using the Logitech Attack 3, I suggest using the "Z". So:
The "Z" is the thing at the bottom where you can push up or down. Its like a knob.
if(joystick1.GetZ() > 0)
else
//the other drive
Unread 02-04-2011, 22:26
so that you can do it then right?
and how would you switch back to the original drive system
like this?
else{
other drive drive
else if(joystick1.GetRawButton(3)){
other drive
Unread 02-04-2011, 22:43
Dacilndak's Avatar
Dacilndak Dacilndak is offline
Matt'); DROP TABLE Users; --
AKA: Matthew Haney
FRC #3729 (Red Knights)
Dacilndak is an unknown quantity at this point
Well, you could do something like
if (joystick1.GetZ() < 1.0 && joystick1.GetZ() >= 0.33)
	// tank drive
else if (joystick1.GetZ() < 0.33 && joystick1.GetZ() >= -0.33)
	// arcade drive
else // if (joystick1.GetZ() < -0.33 && joystick1.GetZ() >= -1.0)
	// holonomic drive (?) ... whatever else
Ideally, then, in the middle of driving you could turn the Z wheel (towards the bottom of the joystick closest to you, like davidthefat said), thus switching drive modes.
I wouldn't recommend using buttons to switch drive modes, as the change in speed can be sudden and you could tear up your drivetrain if the driver isn't careful and/or you aren't ramping your joystick inputs.
Team 3729 - Raiders - Programming Team Co-Captain
2011 Colorado Regional Semifinalist
2011 Colorado Regional Rookie All-Star Award
2011 Colorado Regional Highest Rookie Seed Award
Unread 02-04-2011, 22:52
couldnt i do something like this so stop the tearing apart?
if (joystick.GetTrigger()){
myRobot.Drive(0)
tank drive
my thinking is that when you push the trigger it will stop the robot and then it will switch modes that way you do not have to worry about the robot driving while you are switching modes
at least that is what i think you are trying to do
Unread 02-04-2011, 22:53
i see what you are talking about now after i read it again couldnt we do the samething on a regular controller
Unread 03-04-2011, 00:30
Dacilndak's Avatar
AKA: Matthew Haney
What exactly do you mean by a "regular controller"? The Z-axis wheel is on all of the KOP joysticks.
If you mean just using buttons, then what you seem to be doing there (driving the motor to 0, then using the new drive mode) would certainly work. I would advise, however, adding something like a Wait(0.05); in between the two to allow the robot to come to a bit of a stop or at least slow down - by driving in the new mode immediately, the stop would be basically ignored because you'd be sending it new orders before it had time to stop. It would only stop for a fraction (1/20 in this case) of a second, but it'd really help.
Try doing something like:
int driveMode;
if (joy1.GetRawButton(4) == 1 && joy1.GetRawButton(3) == 0)		// button 4, not button 3
	driveMode = 0;			// flag for tank drive
	drive.Drive(0, 0);		// stop motors
	Wait(0.05);			// let them stop
else if (joy1.GetRawButton(4) == 0 && joy1.GetRawButton(3) == 1)	// button 3, not button 4
	driveMode = 1;			// flag for arcade drive
then later...
switch (driveMode)
case 0:
	drive.TankDrive(joy1.GetY(), joy2.GetY());	// Tank drive
	break;
case 1:
	drive.Drive(joy1.GetY(), joy1.GetX());		// Arcade drive
	break;
default:
	drive.Drive(joy1.GetY(), joy1.GetX());		// Arcade drive (default, no buttons have been pressed)
	break;
to do the actual switching process. The above would make it so that if you press button 4, you swap to tank drive mode and stay in it until you press button 3.
Also, you're transmission won't get ripped apart unless you slam the joystick from 1.0 to -1.0 quickly. Still, it's worth putting in safeties like these, since you can't trust your drivers to remember each time .
Unread 03-04-2011, 10:35
So I should combine a if statement with a casestatment?
Unread 03-04-2011, 13:00
tomy, I'm not sure you understand the way a "drive system" works. Are you expecting to call "TankDrive" once and have the robot switch to tank drive, and later call "ArcadeDrive" once and have the robot switch to arcade drive? That's not what the functions do.
The Drive() functions take joystick inputs and mix them around to control motors. You have to call one of them at least ten times a second in order to keep your robot moving. You can decide which to use every time through your Teleop() loop, and you can change which one you use whenever you want to.
I agree with the suggestion to use the Z-axis "throttle" as the selection between Arcade and Tank drive.
Unread 03-04-2011, 13:12
Ok thar sounds good I just wanted to make sure you could do it
