#196
Re: Minibot climb rate
What's the blue broom-hook thing at the top made of ?
#197
if you're referring to the clip, its actually blue pvc pipe!
#198
are you using the stock 52:1 gearbox? and are those 4" wheels ?
#199
Based on a quick comparison in proportions to the opening in their deployment system, my guess is they are 4.6 inch. It looks like they are made of PVC and wrapped with surgical tubing.
#200
Stock gearboxes, I modded some gearboxes to 10:1 but I didn't invest much thought into them after. The wheels are actually around 5.5", the picture angle is misleading. They use a 4" to 3" PVC pipe fitting for the wheel rim and its 3/8's surgical tubing. Im pleased with the way they came out, and can safely say its a unique design (unlike many little screamer bots out there).
#201
pi*5.5" wheel diameter = 17.3" wheel circumference. 90"/17.3" = 5.2 wheel revs to climb pole (5.2 revs)/(2.2 seconds)*(60 seconds/minute) = 142 rpm At that speed, the motors are generating virtually no torque. Somebody please check my math. |
#202
He noted in passing that he modded the gearboxes to 10:1. Which probably puts him on the wrong side of peak power, but makes a little more sense.
#203
Your interpretation makes more sense I guess. |
#204
The 10.4 to 1 boxes, based on our experiences and pile of smoked motors, won't work with a 5.5" diameter wheel. We ended up with ~3" wheels with our 10.4 to 1 gear boxes. The math doesn't add up to a 2.2 sec time with 52 to 1 boxes either, unless that bot's weight is less than the total of the battery and motors, let alone the wheels and frame, again based on our experiences. |
#205
We used stock (52:1) gearboxes on the minibot. The average time was 2.2-2.3 seconds from bottom of the pole to the top. It weighs around 4.5-5 pounds.
If this helps: ![]() Last edited by WileyB-J : 03-04-2011 at 11:29. |
#206
Our minibot had a 3.5 second climb. Unlike a lot of robots that I saw that used magnets to hold on to the pole. Our magnets were located in our wheels and then covered in electrical tape for traction.
I have attached a picture of one of the early forms of the minibot. the magnets are underneath the thin layer of black electrical tape. We had some problems with deployment early on, mainly due to the fact that the robot was driving down the pole, but other than that it worked reasonably well. |
#208
How did you secure them to the wheel? Did you alternate them N/S ? |
#209
Late in the process we got a 1.7s minibot working with 1/4" tubes covered with surgical tubing. I never understood why everyone thinks magnets are necessary. If you center the minibot's mass left to right and balance the top to bottom mass difference by angling the minibot a bit, magnets are not necessary. Sure the minibot is not trying to climb straight up but it is also not trying to pull the magnets up with it - and its simpler.
#210
