Go to Post Note to self: Go to IRI sometime. - [more]
Unread 10-03-2011, 07:47
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Do not use Jaguars with window motors
My team arm is lifted with two window motors on the same shaft. Because my team is new (2 years) we had only Jags , but the motors had a strange noise when they work together and couldn't lift the arm often. To check the problem we tried the arm with just one window motor and it worked without problems but we wanted two motors because of the strenth, thank to our neighbours team 2630 we replaced the Jags with victors and it is now working.
Why it happend?
I think that the Jaguars are not giving a equal voltage or something so the motors are not in the same speed and opposing to each other.
Does someone have a clear explaination why it happened? because I heard on other teams that it happened to them.
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 10-03-2011, 08:04
JamJam263 JamJam263 is offline
FRC #0263
JamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of light
Re: Do not use Jaguars with window motors
You will probably find what your looking for here. It's a 9 page thread on Window-Jag compatibility issues.
Favorite 2009 quotes:
"Do we really need all of the cRIO or can we cut it in half to save weight?"
Unread 10-03-2011, 08:14
The Lucas's Avatar
CaMOElot, it is a silly place
This is a known issue for Chief Delphi and FIRST. It is the reason for R47-C that allows you to remove the locking pins from the window motor (helps with Jags and Victors).
The best practice with window motors is:
-run them with Spike relays
-never stall them
-don't connect 2 of them together
They are very particular motors designed solely for car windows, not robots.
Robot Inspector
Unread 19-03-2011, 15:17
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
Interesting. Our team has used jags with window motors with no problem. But never 2 connected. One problem i could think of, would be that they are spinning at slightly different speeds, from either the motors themselves or the jags.
Unread 19-03-2011, 16:18
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
Running two of them together creates problems due to worm gears. As they run, their speeds will vary slightly, no matter how careful you are. This causes the worm gears to crack the casing or teeth, as they are being forced to backdrive, which they cannot do.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 19-03-2011, 20:42
DonRotolo's Avatar
Back to humble
FRC #0832
Actually, these motors DO backdrive, that's why the locking pins are in there.
The tendency to backdrive for a worm gear system depends on the angle of the worm gear threads.
Unread 19-03-2011, 20:50
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We have run the same two motors on one shaft in our practice bot for many hours and on our competition bot through 15 matches this weekend and never had a single problem.
And yes they do backdrive a little.
Unread 22-03-2011, 20:22
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
My general rule on window motors: Don't use them.
Unread 28-03-2011, 06:14
Please remember there are slight electrical differences in the left and right motors.
Unread 28-03-2011, 14:59
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
-never stall them
Is there a list of known issues somewhere?
-- Marshal Horn
Unread 28-03-2011, 15:38
The Lucas's Avatar
That would be nice, they kind get lost in all the threads in the technical subforums (many of which could be avoided by using the search or ) . Among all the threads asking the same question or "is this <insert obvioulsy illegal thing> legal?" are some threads where the considerable collective knowledge actually identifies the cause of a tough problem and sometimes a solution. Recent examples are:
2010
Issues with window motors and speed controllers (this thread and others but mostly the one last year that I linked)
The problems with Encoder::GetRate() (only works for half of your encoders)
2011
RS-775 case shorts
Minibot inductors burning out
CAN TImeouts with v28 image
Feel free to add more.
Perhaps mods should sticky more, but people tend to glance over stickies I guess the only way is to to glance over what is being discussed on CD, and focus on the important ones.
Robot Inspector
Unread 28-03-2011, 18:48
TEE's Avatar
TEE TEE is offline
FRC #0201
TEE has a spectacular aura aboutTEE has a spectacular aura aboutTEE has a spectacular aura about
Our arm operates on two window motors, which are controlled by jaguars if I remember correctly, and we have yet to have an issue... http://www.youtube.com/watch?v=6BGJRaam-LU#t=1m38s
Unread 28-03-2011, 22:15
sithmonkey13's Avatar
sithmonkey13 sithmonkey13 is offline
AKA: Nathan
FRC #1178 (DURT)
sithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to all
1178 used a window motor controlled by a Victor for our main lift (continuous rigging). Aside from the speed, we never had an issue with the motor. (The belt slipping, waiting for our main drive train parts to come in, jaguars frying (replaced all the drive jaguars (4) with Victors within 1 hour of uncrating the robot at the St. Louis Regional were several of numerous problems but with the window motor controlled by the victor, we never had a direct motor problem.)
Note: You cannot tell the difference between "OK Go" and "OK No" when there 2 walls between you and the robot. At that point, the only thing between injury and safety for the mechanical guys is their ninja skills.
Unread 03-04-2011, 13:29
Todd's Avatar
Todd Todd is offline
Software Engineer
FRC #1071 (Team Max)
Todd is just really niceTodd is just really niceTodd is just really niceTodd is just really niceTodd is just really nice
Just adding that Team Max (1071) ran an arm with two window motors on a single shaft with two jaguars this year, also without issue over many matches and numerous hours of pre shipping practice time.
We did, early on, encounter some issues with the locking pins on the window motors when our arm was at its point of maximum torque, however some unrelated issues that changed the weight distribution of our arm seemed to mostly resolve them.
Unread 04-04-2011, 15:44
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
WE had similar problems with ourarm but they only showed up during competition which was the first time we had run the arm a lot at one time.
