Go to Post Don't be affraid of trying new things... Even if people say you are crazy, even if you get insulted, even if it involves a lot of time and money, try it. You can't know if it'll work or not if you didn't try it yet. - EDesbiens [more]
Unread 03-04-2011, 23:17
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: CRIO Imaging Tool Error 56
When I was imaging to v28 I was getting those errors. Should be a physical problem on the cRIO. The cRIO has a couple tiny switches in the front (little rocker switches) I'm not sure which ones but some of them need to be switched. There should be a help file on usfirst.org or ni.com but I'm not sure where exactly it is.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
