Go to Post Mark McLeod, spreadsheet whisperer - PayneTrain [more]
  #61   Spotlight this post!
Unread 04-04-2011, 09:40
Re: The Hardest Drive System To Program:
Originally Posted by aaronweiss74 View Post
I'm going to have to agree with all those who said that programming the drive system really isn't difficult at all. The most common systems are ready-made and quite frankly, there's absolutely no good reason other than elitist-ness to rewrite them. If you take programming in FIRST as an opportunity to prepare for programming in the real world, you'll have to realize that you get paid to produce new work, not rewrite already working code. As the old saying goes, don't fix what isn't broken. As for an actual answer, it has to be something complex to the point where you require advanced math...
Welcome to CD. Your enthusiasm and self-confidence are admirable, but as you get older and gain experience you will find that those absolute statements have many shades of gray.
A software problem need not involve advanced math to be complex. It may involve just algebra, geometry, and trig... but require considerable skill and experience to set the problem up properly.
In the real world, many software people get paid to rewrite already working code, be it to make it more efficient, make it more maintainable, make it more re-usable, make it conform to a new customer-required (or company-required) coding standard or language, take advantage of the unique characteristics of a new processor, avoid royalties, or migrate away from a legacy language.
Rewriting library code just to be "elitist" is immature and counterproductive. But assuming that learning is the motivation, at least one good reason to re-write library code is to learn. Some people learn best by doing. Understanding and analyzing an already-solved problem and designing and coding a working solution is one way to do this. Comparing your solution to someone else's can be rewarding and provide deeper insight. It goes without saying that this learning process should not be allowed to jeopardize the project.
  #62   Spotlight this post!
Unread 04-04-2011, 10:43
ttldomination's Avatar
Sunny
Reading through this thread, I do have a question.
Assuming a robot has a crab drive, how would turning of the actually base fair? I would think that since turning would pretty much be comparable to a 4WD, it wouldn't so hot, but my knowledge of swerve/crab isn't whole.
Can anyone confirm this?
1648: 2013-2014
5283: 2015
  #63   Spotlight this post!
Unread 04-04-2011, 15:26
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
The way our swerve drive turns would be to turn the wheels in so that it actually doesn't skid. I know 1717 does this and it is very effective as far as I can tell.
If they didn't turn inward it would be rather difficult to turn I think.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
  #64   Spotlight this post!
Unread 04-04-2011, 15:42
I think he was asking specifically about crab drive (which is a subset of swerve), where all four wheels are driven and steered in the same direction.
With high-traction wheels and a long wheelbase, yes.
  #65   Spotlight this post!
Unread 04-04-2011, 15:48
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Now, this might sound ridiculous, but has anyone thought of putting a "turret". So the Drive train would be a separate system than the turret like a tank.
  #66   Spotlight this post!
Unread 04-04-2011, 15:50
I believe this has been done.
  #67   Spotlight this post!
Unread 04-04-2011, 15:51
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
This Robot comes to mind. So do a few others by team 118.
Kettering Motorsports
  #68   Spotlight this post!
Unread 04-04-2011, 15:53
http://www.youtube.com/watch?v=CAJBC-DDL9w
  #69   Spotlight this post!
Unread 04-04-2011, 15:55
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Originally Posted by Joe Ross View Post
How stable was it? Are you aware if it broke down often or at all?
  #70   Spotlight this post!
Unread 04-04-2011, 16:11
If you crab a long/narrow wheelbase sideways, it becomes a short/wide wheelbase.
  #71   Spotlight this post!
Unread 04-04-2011, 16:26
Of course.
If the vehicle is mechanically limited to crab operation that may be your only option.
If not, it could be argued that it would be easier overall to replace crab software with something more flexible.
  #72   Spotlight this post!
Unread 04-04-2011, 17:28
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Short answer: Swerve drive with 4 independently controlled wheels.
Long answer: Swerve drive with 4 independently controlled wheels that have a limited range of motion. This forces the programmer to limit how the wheels will be pointed as to not tear out the wires leading to the motor powering the wheel (CIM motor in most cases.) It also requires the wheels taking a specific path in order to do this. This path is not necessarily the shortest and most direct, but it should be no more than 180 degrees of travel. An example of this is the attached picture, a portion of team 2421's creation this year. If someone wants to see the code for it, it is available here. Feel free to PM me with any questions you may have
-Alex
2010 Washington DC Regional: Engineering Excellence Award
  #73   Spotlight this post!
Unread 04-04-2011, 17:47
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
From what I can see, you only need 90 degrees of rotation. Personally, from the context of this competition, having 4 independently rotated wheels are too much weight. The swerve system it self is quite heavy, adding unnecessary weight should be avoided. I really see no advantage with 4 independent wheels compared to the "crab" drive. At least the negatives far outweigh the positives.
  #74   Spotlight this post!
Unread 05-04-2011, 00:24
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
I agree with david on this one. While i do see the merit in four independently controlled swerve modules, i think the weight and the limited motors outweigh the benefits of the control. For the case of FRC i think that the crab is more than sufficient.
Expect the best, Prepare for the worst
  #75   Spotlight this post!
Unread 05-04-2011, 00:38
AdamHeard's Avatar
Lead Mentor
I disagree.
Many teams are capable of making such a drive lighter than most teams invest in traditional drivetrains. They then achieve full omnidirectional motion without the drawbacks of a robot sitting on rollers.
