Go to Post My advice is anytime your intuition tells you something, double check it with physics. - tennispro9911 [more]
Unread 04-04-2011, 19:27
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: Would Someone mind looking over my autonomous.
  • Fixed idk how I missed that
  • Ill stick with the normal Waits for now unless I get a problem.
  • Put them in a sequence structure
  • I had problems when I did that also this way I have more customization.
  • Did that
  • That was to 1.clean it up and 2.It was done in teleop where I call those values in weird places. (I assume your talking about the Rotate Max/Min)
  • That's there to make a physical 90 deg into a virtual 90 deg
  • That's how it is in teleop I like consistency.
  • Consistency
  • I've been told and I try.
  • I'm really anal about it and I spend almost twice as much time cleaning code as I do writing it. An NI rep was checking out my code and added some things that weren't perfectly wired I was twitching till I fixed it. You should see my teleop
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
