Go to Post So, volunteer Field Resetters are to meet in the school's weight room for training? :D - Roger [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 18-11-2002, 21:59
Adrian Wong Adrian Wong is offline
#0596 (SciClones)
Adrian Wong is an unknown quantity at this point
Send a message via AIM to Adrian Wong
Autonomous Code
Anyone have any info on how to program this? Does it just run the mainloop without regards to the SERIN command?
Unread 18-11-2002, 22:34
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Somewhat yes, somewhat no.
Basically, it runs the program loop exactly as if it was in non-autonomous mode. The only difference is that all the variables from the OI (p1_x, p1_y, p1_sw_trig, etc) are set to 127 or 0, depending on whether it is an analog or digital input, respectively. The inputs on the RC (rc_sw1, sensor1, etc) still contain the correct values.
One of the bits of the competition mode byte is also set but I can't remember which. It's documented in the default code if you need to know.
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Code From Experience EbonySeraphim Programming 7 14-03-2003 21:56
Autonomous code tutorial miketwalker Programming 2 23-02-2003 12:28
Overcomplicated Autonomous Code EbonySeraphim Programming 33 20-02-2003 21:53
Autonomous code PBoss Programming 7 14-01-2003 15:29
