Re: pic: Team 48 Robot at Smoky Mountains Regional
The roller claw extends 12" with the use of a 1-1/16" pneumatic cylinder inline with the arm. This allows the robot to pick up off the floor, then retract for all other functions. The arm is long enough that the arm does not need to be extended to hang tubes on the top center post, but short enough to fit within the frame in the "home" position.
The dual outer arm rails are 2 x 1 x 1/8" rectangular aluminum tubing with a 1.5 x 1.5 aluminum tube as the telescoping extension. The air cylinder is threaded directly to a plate welded in the end of the extension between the outer rails. Aluminum and Delrin plates support the ends of the outer rails and the back end of the extension for a smooth, well-supported telescoping action.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
