Go to Post If I find a student on my team who came through FIRST having learned nothing more then he wanted to go to MIT, I'll give my self a pat on the back and start counting down to kickoff. - Andy A. [more]
Unread 04-04-2011, 18:46
Happy Birthday! Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
pic: Team 48 Robot at Smoky Mountains Regional
Unread 04-04-2011, 18:48
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: pic: Team 48 Robot at Smoky Mountains Regional
You guys looked great on the webcast. Congrats on the regional win.
I have seen many teams with designs similar to this. Mind sharing how your arm extends? Can it be moved back in aswell (hard to tell from webcast)?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 05-04-2011, 14:16
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
The roller claw extends 12" with the use of a 1-1/16" pneumatic cylinder inline with the arm. This allows the robot to pick up off the floor, then retract for all other functions. The arm is long enough that the arm does not need to be extended to hang tubes on the top center post, but short enough to fit within the frame in the "home" position.
The dual outer arm rails are 2 x 1 x 1/8" rectangular aluminum tubing with a 1.5 x 1.5 aluminum tube as the telescoping extension. The air cylinder is threaded directly to a plate welded in the end of the extension between the outer rails. Aluminum and Delrin plates support the ends of the outer rails and the back end of the extension for a smooth, well-supported telescoping action.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 05-04-2011, 14:36
O-H
Here is a closer look at the arm:
http://www.chiefdelphi.com/media/photos/36507
