Go to Post if you put 3 controls engineers in a room you will get 4 different way to do tuning. - FrankJ [more]
Unread 26-02-2011, 17:29
MikeNimmo's Avatar
MikeNimmo MikeNimmo is offline
Software
FRC #3126 (Flashpoint)
MikeNimmo is an unknown quantity at this point
Re: New Year, New ZomB Dashboard
Just something to look into for the next version:
My team is currently having trouble running both the camera and the meters on the dashboard at the same time. When we try, the camera has a delay of about four seconds and the meters are off by about two. We were not sure if just too much info is being sent to the dashboard so we tried using a remote dashboard and everything was fine. On a side note, the meters and the camera work fine independently.
Unread 26-02-2011, 17:48
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
is this on the classmate? and using DBPackets? I've experienced the exact opposite when using DBPackets sometimes (slow on other computer, fast on driver)
EDIT: I can't believe I forgot to announce
ZomB 0.8
  • Java bindings now follow convention - update your code
  • compiled against cRIO v28
Download
Watchdog.Kill();
Unread 27-02-2011, 13:50
MikeNimmo's Avatar
Software
Yes this is on the classmate but we are actually using TCP instead of DBPackets. When we try DBPackets, NetConsole gives us this message: >>>>Fatal error "When packing data to the dashboard, too much data was packed and the buffer overflowed." in Printf() in C:/windriver/workspace/WPILib/Dashboard.cpp at line 283
EDIT: We are currently sending 9 floats which souldn't be too many. Also we are using ZomB version 0.8.
Unread 27-02-2011, 14:50
byteit101's Avatar
odd, i'm assuming this is not just once? if so, would you mind sending me your code, i've never seen this before.
what is the wait in the main loop? 0.005? try a larger number (like 0.02) and see if its better. i'm also assuming you are using if (z.CanSend())
Watchdog.Kill();
Unread 02-03-2011, 16:37
byteit101's Avatar
ZomB v0.8.1.386
  • MJPEG improvements, should go on and on and on now
  • ZomB button improvements: restart works, Move added (grab it like the titlebar)
  • Build button autofocused, just hit enter
Download
And, thanks to all your support, ZomB has now been download over 4000 times!
Watchdog.Kill();
Unread 02-03-2011, 16:52
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Team 3266 is now using ZomB Dashboard. Thanks a ton!
Why aren't you guys going to Buckeye this year?
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 02-03-2011, 17:05
byteit101's Avatar
Your welcome! A bunch of people on our team would not be able to make it, so we went to Knoxville instead (which is 451 miles away, it must be a sign). I would have liked to be a little closer though! (2 hrs vs 7 hrs)
Watchdog.Kill();
Unread 04-03-2011, 20:34
byteit101's Avatar
Ever wanted a Git or Mercurial version of the ZomB Subversion repository? Well, there is now an official Git mirror and a Mercurial mirror.
*Note that these are simply mirrors, and all pull requests will be denied (though I may create a patch from it). Instead, create a patch and send it to me, as a PM here or as a tracker on FIRST Forge.
Watchdog.Kill();
Unread 05-03-2011, 13:15
Tommithy Tommithy is offline
FRC #2410
Tommithy is an unknown quantity at this point
ZomB dashboard is awesome!!!!
BLARG!!!
Unread 09-03-2011, 17:35
byteit101's Avatar
ZomB Dashboard System v0.8.1.393
  • FPS view on camera, variable FPS recording option for real time videos, not fast or slow
  • Basic Triggers support, start and stop multiple cameras, call code
  • Stop the AutoListen on Run
  • Sizable labels and buttons (Finally!)
  • Running in driver not quite as locked down for non-classmate users, look at Unlocking the Driver account
Download v0.8.1.393
Watchdog.Kill();
Unread 16-03-2011, 15:27
byteit101's Avatar
ZomB v0.8.1.397
  • New (and smarter) AutoListen look
  • Error boxes!
  • bunch of bug fixes
Download v0.8.1.397
hg: 336:a9f5ee239c7f
git: 56f6037843fa231ef0fc
Watchdog.Kill();
Unread 27-03-2011, 17:33
byteit101's Avatar
ZomB v0.8.1.401
  • Bug fixes
    • recording should now actually work by default (Thanks Robby Unruh!)
    • triggers now actually save correctly
    • Fixed artf1343: Image background on targets corrupts files (Thanks Robby Unruh!)
  • MJPEG camera param now accepts ip?fps format (ex: 10.4.51.90?30 means camera with ip 10.4.51.90 has 30fps)
Also, if you can't get DBPackets, change the source to custom and add port 1027 (if I remember correctly), so it looks like: zomb://.451:1027/DBPkt
If you are using Java, somewhere in the update line, C++ and java compatibility broke, so you need to use DBPacket from svn r287 or before (different API, I'll post the current one shortly)
Download v0.8.1.401
hg: 340:bb5b73e3c95b
git: 8fbf5e3c1ee46f69714e
Watchdog.Kill();
Unread 28-03-2011, 01:27
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Looks awesome,
can't wait to get it up and running.
one quick question
under Being legal over TCP (DBPacket is always legal):
it says "Don't use a camera on port 2, it will also broadcast on 1180"
do we have to just plug the camera right into the router then?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 28-03-2011, 15:02
byteit101's Avatar
Originally Posted by Mk.32 View Post
Looks awesome,
one quick question
Correct (if the "router" you are referring to is the D-Link on the robot)
Watchdog.Kill();
Unread 06-04-2011, 11:19
byteit101's Avatar
Get ready for week 6 with
ZomB v0.8.1.409
  • Java bindings sort of work again (use DBPacket)
  • Toolbox docked, right click in toolbox to change (restart required)
  • Initial Smart Dashboard protocol support, try ''zomb://.451/Smart'' as a custom url
  • Menu Improvements
  • Camera.Refresh exposed to triggers
  • Bug fixes & other improvements
Download v0.8.1.409
hg: 346:681d781b18cd
git: b5de628038cd273b93b6
Watchdog.Kill();
ZomB Dashboard System 0.7 coming soon byteit101 Programming 1 21-12-2010 15:41
ZomB Dashboard 0.6: Beta testers wanted byteit101 Programming 17 29-07-2010 15:52
ZomB: a C# Drag and Drop Dashboard byteit101 Programming 39 14-05-2010 21:01
pic: New year, new hair, new title vic burg Extra Discussion 1 07-10-2006 23:43
New year, new ideas!! Tyler Olds 3D Animation and Competition 3 08-10-2003 00:23
