Go to Post Haters gonna hate; kill 'em with kindness. - Taylor [more]
Unread 06-04-2011, 08:15
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Replacing cRIO
Have you replaced your cRIO? If so why?
Failed unit?
Age?
Other reasons?
Unread 06-04-2011, 12:37
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Re: Replacing cRIO
Team 230 has replaced 2 cRIOs this season:
1). It was fried (likely by metal shavings dropped in from "above" ). NI shipped us a replacement overnight!
2). The second cRIO which was a backup we have was replaced after the Suffield Shakedown Scrimmage where we spent the entire day trying to establish communications with the help of the FTAs and everyone else there. That cRIO had been capable of communications using the old bridge from 2009 but would not connect up to the DLink. When we got our first replacement cRIO it connected flawlessly... and then we had to have some discussions with NI to get the 2nd cRIO replaced.
Note that I can't be sure which was which, but we had purchased one as a replacement for a "lost" system in late March/early April of 2009 and I believe the other was purchased in November/December of 2009 in preparation for the 2010 season.
So... I guess I would say that they were both replaced because they failed.
Unread 06-04-2011, 12:44
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Replacing cRIO
We replaced ours because it got rained on. After working intermittently for about six months, it finally lost power.
Hi!
Unread 06-04-2011, 13:24
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Replacing cRIO
We purchased a second cRIO because we damaged the ethernet port that the radio connects to while driving in our shop (we can't do wireless because there is to much other radio traffic there). It still works...but only by very carefully plugging in a cable. The *broken* one will probably be used for a practice bot.
Unread 06-04-2011, 15:19
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Replacing cRIO
A few years ago, we replaced one because it had come with bent pins where the modules connect. We sent it back, and NI sent us a new one pretty quickly.
Unread 06-04-2011, 15:48
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: Replacing cRIO
We had one die at GSR this year. A loaned unit got us through he rest of the day and we replaced it with our back up for Palmetto.
I've since repaired the dead one. The 2amp internal fuse had opened, and once replaced it functioned fine. It's a surface mount type and was in a frustratingly difficult location, but finally came out. I don't know why it failed, but things seem okay now. It should do fine for testing and off season development.
Unread 06-04-2011, 19:08
biancs15's Avatar
biancs15 biancs15 is offline
Driver, Design and Manufacturing
AKA: Austin
FRC #0610 (Coyotes)
biancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to behold
Re: Replacing cRIO
We have replaced one C-Rio this year.
At GTR we were losing communications during the match, and we thought it had to do with a malfunctioning cRIO constantly re-booting. So obviously, we replaced it. It turned out not to be our cRIO, but a banebots motor
2013 Team Co-Captain, Base driver, Head of Design and Manufacturing
2013 Waterloo Regional Finalists
2013 BAE Systems Regional Winners
2012 Arizona Regional Winners
2012 GTR East Regional Finalists
2011 Galileo Division Finalists
2011 Waterloo Regional Finalists
2011 GTR West Regional Finalists
"When in Rome"
Unread 07-04-2011, 11:08
Re: Replacing cRIO
I'm curious why you went to so much trouble, rather then have NI repair it.
Unread 07-04-2011, 14:19
bdbayes bdbayes is offline
Captain
FRC #2927 (Pi Rho Techs)
bdbayes is a jewel in the roughbdbayes is a jewel in the roughbdbayes is a jewel in the rough
Re: Replacing cRIO
Where can I find information about getting a cRIO replaced?
Unread 07-04-2011, 14:31
Re: Replacing cRIO
From https://decibel.ni.com/content/commu...iew=overview#/
Want to talk to someone? Call (866) 511-6285 from 1 p.m. to 7 p.m. Central Time for:
* cRIO repair
* Purchase extra cRIOs for your team, or you can...
Unread 07-04-2011, 16:51
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Replacing cRIO
We recently just brought a 2nd CRIO from NI with the FIRST discount as a backup and for use on our test robot.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 07-04-2011, 17:36
Getting old
FRC #0095
Re: Replacing cRIO
I did that kind of rework for a living, for a while. Part of me wanted to see if I still had the hand for it. Seemed like a fun project at the time. The initial thought was that the problem was metal chips that might have worked into the housing. Once I had the board out I just kept going.
Unread 10-04-2011, 00:25
11douglash 11douglash is offline
FRC #1072
11douglash is infamous around these parts11douglash is infamous around these parts
Re: Replacing cRIO
Yeah. We have. Once.
Two years ago, ours fried during build. due to an unknown cause. We were very careful with ESD, and the coders were re-formatting it very frequently in the days before it died. Either way, we were somewhat sure it wasn't out fault, but we can't be 100% shure.
We called up NI, explained to them that we are a FIRST team, and explained to them the situation. They swapped out our old one for a new one, as they wanted to take apart the cRIO to figure out what really went wrong with it. If it really was code, they want to know.
Unfortuantly, it took nearly a week to ship. You can be shure that we now have a spare cRIO on hand during build.
Unread 10-04-2011, 09:59
Billfred's Avatar
Billfred Billfred is offline
Re: Replacing cRIO
We think we will need to do something with ours in the postseason. It stopped getting power Saturday morning at Peachtree, and we've been using loaner units since. (That said, we experienced symptoms that indicate our cRIO was losing power after hard hits during the Palmetto eliminations. We'll be diagnosing that in St. Louis.)
Unread 10-04-2011, 11:04
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: Replacing cRIO
Ours fried after FLR last year. NI replaced it quickly. We're not sure the cause - it looked electrical, happened while the robot was driving, and nothing was touching the cRIO. Personally, I suspect static electricity may have gotten there somehow.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
