Go to Post ...these guys have taken it to a new level. (I want to be part of a team like that.) - Tetraman [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 19-11-2002, 18:48
Alphawolf829's Avatar
Alphawolf829 Alphawolf829 is offline
#0506 (StART)
Alphawolf829 is an unknown quantity at this point
Send a message via AIM to Alphawolf829
Unhappy Finding myself quite confused...
Im took a look at the EDUrobot program and got a headache. Im thoroughly confused. I was just getting adjusted to the previous method. Need help. I don't know what im doing anymore. (as if I knew before)
"Imagination is more important than knowledge, knowledge is limited, imagination encircles the world." - Albert Einstien
Unread 19-11-2002, 18:56
Melissa H. Melissa H. is offline
MIA
AKA: Melissa
Melissa H. is on a distinguished road
I haven't gotten a chance to look at the EDU bot program yet...where can I get it? (My team hasn't gotten around to the edubot yet...not enough time...) Is the EDU bot program in PBasic?
FIRST Robotics Alumni =D
Unread 19-11-2002, 19:02
#0506 (StART)
check the innovation first site it shows the default program it looks different, Im not sure it is so it might just be the same.
Unread 19-11-2002, 19:14
#0506 (StART)
ok well I guess im just rusty it is starting to make sense.. any need to know information though would be greatly appreciated...Oh can I still program it the same way?
Unread 19-11-2002, 19:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I am not a programmer but I'm guessing it's different because the EduBot uses servo-type motors instead of PWM controlled normal DC motors.
Unread 19-11-2002, 23:21
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
There is quite literally no differences between programming the mini-RC and the big-RC--just make sure you flip the switch from "tether" to "program."
Anyway, the PWM outputs have a fourth pin for power, but from a software standpoint are no different than regular DC motors.
The only new things are the addition of autonomous mode and user mode. Under autonomous mode (accessed by setting your team number to 0), the OI only sends 127 (for analogs) and 0(for switches) to the RC. Whether are not you are in this mode can be determined from one of the bits of comp_mode, but I can't remember which--just check the documentation.
You enter user_mode when the OI is set to display user data (by pressing the select button repeatedly). In this mode, out8-out15 each correspond to a bit of the value that is displayed on the OI instead of corresponding to LEDs.
There's also an "oscillator" output, but I don't really know what it does or what types of devices could be hooked up to it. Any electrical people want to shed some light on this?
--Rob
Unread 22-11-2002, 22:09
Morgoth Morgoth is offline
#0471 (Cybertigers)
Morgoth is an unknown quantity at this point
Everyone says that you should look at the default code. But it hasn't been at Innovation First's website for atleast 2 months now. I have been been trying to download it but they keep pushing back the release date. Now it's at December 1st. Is there any other place I can download a beginner's guide to PBASIC?
Unread 23-11-2002, 00:51
What default code do you need? The EduRobot code is posted there, and the full RC code from last year is available at the codex http://www.first-codex.net under 2002 code in the code repository.
Unread 16-12-2002, 20:19
Norm M.'s Avatar
Norm M. Norm M. is offline
Norm M. will become famous soon enough
--Rob
The oscillator output should match up with the frequency required by a polaroid distance sensor. Just what you need to automatically fire your pick axe when your opponent.... Ooops, I meant just what you need to latch your grapple when the goal is close enough.
Other pieces which I might guess at- The previous OI was capable of Team #s in excess of 999, it just wouldn't display them correctly. I suspect there is minimal change in functionality with the 'new' OI. We have used the mini-robot controller in our 'other robots' for several competitions. The basic coding is all the same, you are just missing half the outputs and inputs.
Regards-
Norm Muzzy
need help with finding a scholarship angier314 Career 4 21-01-2004 13:13
Finding New People Josh547 Chit-Chat 9 17-01-2004 11:56
Confused on Crab Drives NateBot16 Technical Discussion 3 16-11-2003 10:26
Need some help finding webpages archiver 2001 0 24-06-2002 02:03
Help in Finding Polycarbonate Sheet AWiser General Forum 7 28-01-2002 23:37
