Go to Post People were learning left and right. 14-year olds knew what a pitch diameter is... cool stuff. - Andy Baker [more]
Unread 10-04-2011, 02:06
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
BaneBots p60 falure
at our regional we had a p60 fail in a way i have not ever seen before, and i was wondering if any other teams had advice on how to prevent this.
an 1-81 P60 with an rs550 on our roller got hit by another robot, and the 4 screws that hold the gearbox together pulled out all of the threads in the aluminum block on the motor side of the gearbox. it was repaired by putting 2 screws in either side, and using an FTC threaded standoff in the middle. this solution worked O.K.
has anyone else had this problem
Unread 10-04-2011, 02:22
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: BaneBots p60 falure
Easy answer: don't mount it where it's going to get hit! (Or shield it.)
Somewhat more complicated answer: this could be a manufacturing problem related to a series of poorly-tapped mounting holes. It could also be an inadequate piece of aluminum—maybe the wrong temper or alloy, leading to unexpectedly low pullout strength. Maybe the tie rods are threaded with too small a thread in the first place—but it's hard to say for sure what's adequate, since I doubt that BaneBots intended that the gearbox be exposed to large tensile loads. (Does it look like the thread was scraped off of either the tie rods or the inside of the holes?)
Do you have any pictures of the failed parts?
Unread 10-04-2011, 02:33
AdamHeard's Avatar
Lead Mentor
When our gearboxes arrived, we noticed the provided screws were of poor quality, and that they only threaded into the block maybe .080", tops (the block is .3" thick). Different number of stages will change what screws are provided, but I would imagine similar issues could exist among all types.
We replaced them with proper length, and quality screws.
Unread 10-04-2011, 03:46
Will BaneBots ever get the simple things right?
Unread 14-04-2011, 20:20
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
The same thing happened to us in build season. We had some older gearboxes which were really solid and had partially threaded socket head bolts that were about 1/2" longer than the gearbox, but the new ones come with screws that are just asking to get stripped. Who knows why BB changed the screws, but the solution is definitely longer screws right after you grease your gearboxes.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
