Go to Post If you think it is such an outrage, then be a do-er and not a talk-er. - BrianBSL [more]
Unread 10-04-2011, 12:24
PriyankP's Avatar
PriyankP PriyankP is offline
FRC #0188 (Woburn Robotics)
PriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud of
Re: Bad luck, or poor execution?
Originally Posted by nitneylion452 View Post
our driving seemed to be very off, our drivers would twist left and the robot would rotate right. We attempted to fix this, but with no success (we believe that the issue was our encoders, one on each wheel, were "arguing" with each other, but we didn't think of this until it was too late).
If something like this happens and you don't know where the problem was or how to fix it, the quickest solution would be to get rid of the encoder code all together. Encoders improve the base control, but they're not a must have sensors!
Similar thing happened to 188 last year. We had meccanum base and we had encoders on all four pods. The encoder code that we had was written using the practice robot and it worked beautifully until we got to our first regional. The encoder code didn't work on the competition robot. We spent about 3-4 hours trying to fix it with no luck, eventually we decided to get rid of the code and it turned out that as long as the battery was fully charged, the base would go straight.
Anyways, in short, sensors are great but you should always have code that doesn't depend on sensors. This year we had two versions of the code, one that uses sensors for better control and one that uses no sensors (skeleton code). Always learn from past mistakes. I have a feeling you guys won't have a similar problem next year.
My $0.02.
Champs Schedule Highlighter App [CD Thread]
#### XYZ Regional Finalists
Unread 10-04-2011, 14:08
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
It took me 3 years to get my programming mentor to finally keep "drive straight" code OUT of tele-operated period. It's "useful" but isn't necessary to drive in the game. In the end, it robs us of torque for acceleration.
Essentially, due to drift and slip, we don't even use our drive train encoders or gyro after autonomous. The caveat with this is that the driver has had plenty of practice on an open-loop skid-steer system.
GitHub
Unread 10-04-2011, 14:36
AdamHeard's Avatar
Lead Mentor
Poorly tuned control loops are worse than no control loops; A good lesson to be learned...
Also, once you reach a certain point of quality with your drive (minimizing friction, etc...) the "Drive straight" code becomes almost useless. Most of our recent drivetrains have had no drift issues.
Unread 10-04-2011, 17:22
RayTurner1126's Avatar
RayTurner1126 RayTurner1126 is offline
team co-lead, mechanical lead
FRC #1126 (SparX)
RayTurner1126 will become famous soon enoughRayTurner1126 will become famous soon enough
Smile Re: Bad luck, or poor execution?
actually, building a "sophisticated bot" is not always the best, often the most simple designs that have you saying "why didn't we think of that??" are the best!
What time is it?? 11:26!!!
Go SparX on 3!!!
Unread 10-04-2011, 17:39
OZ_341's Avatar Unsung FIRST Hero
OZ_341 OZ_341 is offline
#0341 (Wissahickon)
OZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond repute
Amen to that!
2010 Championship Chairman's Award
2016 MAR District Champion (thank you 225 & 1257)
2016 Galileo Division, #6 Seed, 9 W - 1 L
2016 MAR District Innovation in Controls Award
2016 Westtown District Finalist (thank you 4954 & 484)
2016 Westtown District Imagery Award (It took 17 yrs)
2016 Hatboro District Judge's Award
Overall Record 49 W - 21 L
Unread 10-04-2011, 18:03
Joe,
Where in Philadelphia are you and your team located? My team and I will be running workshops on robot design, wiring, electronics, and automation sometime this summer or in the fall before build season. Let me know if you are interested or just want some help in general.
Also, if you could, post up a few pictures of your robot. I didn't get to go around and pit scout like I usually would, so I don't remember your robot. Pictures and video would help identify key problems.
Akash
Unread 10-04-2011, 18:26
nitneylion452's Avatar
AKA: Joe Lee
We are located in Northeast Philadelphia and operate out of Father Judge high school.
For pictures, the only ones I have on hand are very basic images of the robot early in the build season, but it should be enough to remind you of our bot.
The final design for the tower had it standing up at all times. Like I said, this was early in the build season.
Also, here are some specs:
  • mecanum wheels powered by 4 cim motors with Toughbox gearboxes
  • encoders on each of the gear boxes
  • elevator/forklift design manipulator powered by window motor
  • encoder on elevator to determine heights
  • IR distance sensors to measure distance from alliance wall
Unread 11-04-2011, 13:14
jcbc's Avatar
jcbc jcbc is offline
AKA: Julie
jcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the rough
We used Sharp IR distance sensors to get the distance from the alliance wall at the Finger Lakes Regional and discovered that they do not give reliable numbers for the brightly lit diamond-plate wall at competitions. We switched to a sonar sensor (XL-MaxBotix-EZ2) for the Philadelphia Regional and were able to get a much better reading of the distance to the alliance wall.
