Go to Post We're 3 pounds over. Drill until the hole saw is too hot to touch, then go find something else to cut off while you wait for it to cool down. - Richard Wallace [more]
Unread 10-04-2011, 19:18
Bryany's Avatar
Bryany Bryany is offline
FRC #1094 (Channel Cats)
Bryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the rough
Question Untested Conveyor Claw Design
During the build season, one of our design ideas was to have an elevator lift attached to an extending 'hypotenuse' that would be fixed to the rear. This extender would be a track for our roller-claw to travel from one side of the robot to the other. A spool and 9.5ft cable would be responsible for pulling the claw from one end to the other, and would also mechanically pull the claw over whenever the elevator was raised. Gravity would pull the claw back down. The idea behind all this was to prevent the need to turn around after getting a tube.
Not having much knowledge in 3D CAD, I made a digital model the way I did know how, which was to make an executable 'game' that allows the user to 'control' the design in a scale environment. You can access it here:
http://www.bearealis.com/games/1094ProtoConveyor.exe
However, we didn't go this route, because it was getting too late in the season to prototype anymore, and we hadn't much positive experience with spools anyway. So what are your thoughts on this, now that we've seen actual matches in play? Would this design have been a trouble-maker, or should it be kept in mind for future years?
Free One-Person Powerful Objective Performance Scouting PC Program from 1094:
http://www.chiefdelphi.com/forums/sh...63#post1235263
Unread 10-04-2011, 20:51
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Untested Conveyor Claw Design
Wow, that actually sounds really cool.
The problem would be getting the claw back down. You really don't want to rely on gravity, and there isn't really a spring that would provide a constant force from 8' to 6"
You could have a second motor used to pull it down, and be very careful not to let the two out of synchronization.
It also doesn't look like you'd need to be able to rotate the tube, although it may be helpful. The problem is that it's a lot of motors on there -- two to rotate the rollers and another to rotate the entire claw. Then another three for movement of the entire thing.. that's six motors, assuming you don't have to double up on anything.
But again, it's a really neat design, and it may just work.
Unread 10-04-2011, 20:55
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
How about a constant force spring?
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 10-04-2011, 20:56
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
I think he was referring to the difficulty in finding a constant force spring that works from 6 inches to 8 feet stretch, nevermind just finding a spring that stretched that much at all.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 10-04-2011, 21:19
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
The program doesn't work for me but a continuous loop or a 2nd cable counterwound onto the same axle can often be used to drive a cabled mechanism in both directions.
Unread 10-04-2011, 21:35
WizenedEE's Avatar
AKA: Adam
The problem with that is that the length of the loop changes, but there might be some way around that.
Unread 10-04-2011, 23:28
Nick Bouressa Nick Bouressa is offline
Mechanical Lead
FRC #0166 (Chop Shop 166)
Nick Bouressa is an unknown quantity at this point
166 has an elevator style cable driven lift and we ran into the same problem. We ended up attaching rubber-bands on the downward cables to act as tensioner. They are cheap, simple, and light weight. They work very well and we have not had any issues with them (yet). And if the rubber-bands do break you NEED a back up so it doesn't fail catastrophically.
Our team motto...
"THINK!, There must be a harder way!"
2011 GSR Chairmans winner
Unread 27-05-2011, 04:59
Melvin Melvin is offline
Melvin is an unknown quantity at this point
I hope you would have found the solution by now. It is really an awesome design. If you had an idea of 3D CAD then it would have been great because you get a clear picture of the working of the conveyor. It is better to use another motor instead of relaying on gravity.
__________________________
conveyors
Unread 27-05-2011, 06:26
I gotta say, this is a really awesome design. I too hope you figured out a way to make it work. Awesome entertaining little game too! Nice work.
Unread 27-05-2011, 09:30
JeremyLansing's Avatar
JeremyLansing JeremyLansing is offline
Team 967 Alumni
FRC #0171 (Cheese Curd Herd)
JeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud of
Niiice, that's definately my new favorite game!!
Unread 29-05-2011, 09:42
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Team 1515 had a simple elevator design, gravity returned, and it worked fluidly and effectively. However, I think that running a second wire rope line the other way on the same drive-shaft would be a simple solution to that problem. Continuous loops tend to be difficult in pullied lift systems.
Also, Can someone please post a screenshot of the game?
Thanks!
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 01-06-2011, 16:40
GCentola's Avatar
GCentola GCentola is offline
Strategical Tactitian
AKA: Garrick
no team (SparX)
GCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud of
Definitely a cool design! It looks like it would make hanging tubes easy because you can rotat the claw AND the tube, which is pretty awesome. Doesn't exactly look easy to pull off, but hey, this is FRC! Also, it's a great little game of catch the tube from the feeder station and hang it!
GO SparX on 3!!!!!
Check us out at:
http://www.gosparx.org
http://www.facebook.com/SparX1126
I Love Two Pencil Designs!
Unread 02-06-2011, 21:22
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
This is an interesting design. The one big advantage it has over the elevators (which, I think, were largely dominating in this game) is the ability to hang on the opposite side of pickup. However, this then brings up the question: is this design better than the various arm designs that could hang on both sides?
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 07-06-2011, 19:09
Bryany's Avatar
The only thing I can think of that might make it better than the alternate arm design is a closer center of gravity. I think this is a big reason why elevator designs worked so well. We ended up just using a plain arm design, and speaking as the driver, the CoG of an arm makes fine control tricky when the arm is up. (of course, if your arm is fast enough, it wouldn't need to be up very long) Also, a different distance is needed to hang on different heights when using an arm.
