Go to Post Wow, an entire thread with positive comments. I must be on the wrong forum... but my URL still says chiefdelphi.com. Hmmmm... - Chris Hibner [more]
Unread 11-04-2011, 10:30
Bob Steele's Avatar
AKA: Bob Steele
Re: Team Update #21
Originally Posted by pwnageNick View Post
Bottomline, if you (your team) wants to use a phone/iTOuch/iPad/laptop/etc. use it. When you send your team rep up, they can have whatever they want with them. In addition, have them bring your team copy of the rules (this is assuming your team has an updated set of rules, which you should), and make sure the person is ready to pull the rule and update out. If you have that, then the head ref will go over and pull out his rules and confer with you, and it should be fine. Just make sure you're polite with it. There's a reason they came up with the update, and I doubt anyone will run into any more problems because the head refs will probably be notified about this latest update.
Sounds good to me... perhaps you should have this rule on a piece of paper.. and not on a "illegal" electronic device....but hmmmm doesn't that give you an advantage? or if your team did scouting doesn't that give you an advantage... ???
So if a student has to wear glasses... isn't that something that gives you an advantage...
maybe we should just determine alliances randomly....
NOTE: My comment in this post is
SARCASM.... not intended to be taken seriously...
By the way I have all of the rules on a Kindle...
I am hoping that someone will post the entire QA in a PDF format so it would be available... it could come in handy...
see you in St. Louis!!
