Go to Post You'll want to start with P, add some D to help prevent overshoot, and then add some I to help it get to the correct height if it isn't there from the P and D. - AustinSchuh [more]
Unread 11-04-2011, 11:14
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Logitech Attack 3D Pro- Hat Switches
Hi all-
I don't currently have access to a Attack 3D Pro joystick, (although we use one for our drive system) so I can't test this, and I haven't been able to find it via searching.
Does anyone know what the "numbers" are for the hat switch buttons? Since the trigger is, for example, GetRawButton(1), what are the 8 hat switch buttons?
Thanks!
Unread 11-04-2011, 14:52
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Logitech Attack 3D Pro- Hat Switches
They are not buttons, they are axies 5 and 6 (iirc)
So GetRawAxis will return 1, 0, or -1, depending on the position (don't remember which is which, sorry)
Watchdog.Kill();
Unread 12-04-2011, 06:50
AKA: Matt B
FRC #1771 (1771)
But there are 8 positions on the hat switch?
Unread 12-04-2011, 07:40
9 positions, if you count the center one. That perfectly matches the three possibilities on each of two axes.
Unread 12-04-2011, 08:04
msulaimain's Avatar
msulaimain msulaimain is offline
AKA: Muhammad Sulaiman
FRC #3346 ([{Kamikaze Komets}])
msulaimain can only hope to improve
Send a message via AIM to msulaimain Send a message via Yahoo to msulaimain
You could always use a x box 360 controller. More fun in my opinion and comfortable.
int main()
::::::::: include=>commitment;
::::::::: int=>school name=>Asheboro::High
::::::::: int=>team name=>Kamikaze::Komets;
::::::::: Priority_Queue=>FRC Championship::2012;
::::::::: Max_Element=>Teamwork;
