Go to Post you know you're going to meet someone important, so you put on your robotics team shirt. - NorviewsVeteran [more]
Unread 10-04-2011, 19:08
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Deploying code without cRIO
Is this possible? I'd like to debug some code in the off season, but won't have access to a cRIO for a good while.
* I don't mean compiling!
Thanks in advance.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 10-04-2011, 20:51
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Deploying code without cRIO
What do you want to be able to do after you've deployed the code?
Unread 10-04-2011, 21:02
DonRotolo's Avatar
Back to humble
FRC #0832
Um, deploy to what?
Do you mean "something that walks and talks and quacks like a cRio but isn't one" - a cRio emulator for Windows for example?
Unread 11-04-2011, 06:42
I mean just run my program as normally- minus a cRIO. Not from the dashboard because afaik, you'd need to be tethered to something... but from the output window in Netbeans. Would a main + startCompetition method do this?
But if there is a cRIO emulator, that would be nice, too. I saw an early version of one awhile ago, but I don't think that's what I need.
@WizenedEE: I want to be able to read joystick values and test a control board live time from the output window, if possible.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 12-04-2011, 00:42
WizenedEE's Avatar
AKA: Adam
So you want something that will do the same printf commands as the C-RIO does and with the same joystick functions? What we were trying to get at is if you wanted to run some wheels, flash some lights, display to a computer screen, or something else.
To get joysticks, you'd have to connect to the driver station software, and I doubt that's easy without the programmed C RIO. If you wanted to learn about how to read a joystick connected to your computer, though, USB joysticks get recognized by windows and you could skip the DS -- just plug it into your own computer. Reading that Cypress IO board could get harder though.
Unread 26-06-2011, 03:38
ajc ajc is offline
flourishing
AKA: Andrew Chen
FRC #0192 (GRT)
ajc is an unknown quantity at this point
It's been done.
