Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 12-04-2011, 11:31
Nirnaeth Nirnaeth is offline
Coach/Mentor
AKA: Michael Liang
FRC #6367 (The Brooke High ElectroLights)
Nirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud of
3.5mm audio patch cable and power
Quick question, as I can't find any information online. Can I use a 3.5mm audio patch cable to run power to my robot components. A student is wondering if we can use the female and male connectors for ease of use. First, is this possible, and second, is it legal?
Unread 12-04-2011, 11:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: 3.5mm audio patch cable and power
If you're planning on using it to run power from the power distribution board, first determine what size of wire is needed for use with which circuits. Then determine what size wire is in the cable you're planning to use.
I think you'll find that it's quite illegal, if only because the wire is way too small.
Unread 12-04-2011, 11:39
Coach/Mentor
AKA: Michael Liang
That's what I thought. I remember hearing somewhere that the maximum current, even through heavy-duty 1/4 TRS cables was somewhere in the ballpark of 12-15A.
Unread 12-04-2011, 12:10
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
You could just as easy use some male-female tab crimp connectors for quick connections.
Unread 12-04-2011, 14:38
Mike,
The bigger problem is that the contacts on any phone plug/jack combination allow two contacts to be shorted by the mating connector during insertion. There is only one manufacturer that I know of that has locking phone plugs in the 1/4" size that would prevent the connector pulling out during motion. If you think about it, there is no large surface area contact when the connectors are mated.
The Neutrik mono version of the 1/4" claim current rating of 15 amps or less. The stereo (three conductor) is likely much less. Please be advised that all phone plugs are not made identical. Extreme variations exist in finished diameter, plating, insulation and tip design.
Unread 28-04-2011, 12:02
Coach/Mentor
AKA: Michael Liang
What about banana plugs? Anyone seen success with those?
Unread 28-04-2011, 12:39
You may want to get some Anderson connectors. Similar to what the battery has, but there are versions that will go onto an individual wire, then lock together in bundles.
Unread 28-04-2011, 17:15
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
http://www.alliedelec.com/search/pro...px?SKU=8030116
We just got them, and love them. They are able to handle up to 45amps perfect for motor connections.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
