Go to Post My wife got mad at me when I told her I wanted to name our daughter Lotus. "What you mean the software?" she squawked. "No I mean the flower." I said. geeks, I swear.... - Koko Ed [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
  #196   Spotlight this post!
Unread 31-03-2011, 09:07
Re: Minibot climb rate
Originally Posted by WileyB-J View Post
meet richard.
What's the blue broom-hook thing at the top made of ?
  #197   Spotlight this post!
Unread 31-03-2011, 22:05
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
if you're referring to the clip, its actually blue pvc pipe!
  #198   Spotlight this post!
Unread 31-03-2011, 23:57
are you using the stock 52:1 gearbox? and are those 4" wheels ?
  #199   Spotlight this post!
Unread 01-04-2011, 01:12
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Based on a quick comparison in proportions to the opening in their deployment system, my guess is they are 4.6 inch. It looks like they are made of PVC and wrapped with surgical tubing.
  #200   Spotlight this post!
Unread 02-04-2011, 19:00
WileyB-J's Avatar
FRC #4976 (Rebels)
Stock gearboxes, I modded some gearboxes to 10:1 but I didn't invest much thought into them after. The wheels are actually around 5.5", the picture angle is misleading. They use a 4" to 3" PVC pipe fitting for the wheel rim and its 3/8's surgical tubing. Im pleased with the way they came out, and can safely say its a unique design (unlike many little screamer bots out there).
  #201   Spotlight this post!
Unread 02-04-2011, 20:04
pi*5.5" wheel diameter = 17.3" wheel circumference.
90"/17.3" = 5.2 wheel revs to climb pole
(5.2 revs)/(2.2 seconds)*(60 seconds/minute) = 142 rpm
At that speed, the motors are generating virtually no torque.
Somebody please check my math.
  #202   Spotlight this post!
Unread 02-04-2011, 20:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
He noted in passing that he modded the gearboxes to 10:1. Which probably puts him on the wrong side of peak power, but makes a little more sense.
  #203   Spotlight this post!
Unread 02-04-2011, 22:24
OK, is that what he meant? I thought that was an aside. The way I read it, he modded some gearboxes but then decided to use stock (as-is) ones.
Your interpretation makes more sense I guess.
  #204   Spotlight this post!
Unread 03-04-2011, 01:25
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
I also took it to mean that the gear boxes on this bot were the original 52 to 1 ratio.
The 10.4 to 1 boxes, based on our experiences and pile of smoked motors, won't work with a 5.5" diameter wheel. We ended up with ~3" wheels with our 10.4 to 1 gear boxes.
The math doesn't add up to a 2.2 sec time with 52 to 1 boxes either, unless that bot's weight is less than the total of the battery and motors, let alone the wheels and frame, again based on our experiences.
  #205   Spotlight this post!
Unread 03-04-2011, 09:13
WileyB-J's Avatar
FRC #4976 (Rebels)
We used stock (52:1) gearboxes on the minibot. The average time was 2.2-2.3 seconds from bottom of the pole to the top. It weighs around 4.5-5 pounds.
If this helps:
  #206   Spotlight this post!
Unread 12-04-2011, 13:04
AlDee AlDee is offline
FRC #1099
AlDee is an unknown quantity at this point
Originally Posted by jskene View Post
We were consistently getting ~1.2 seconds. We got our minibot measured by team 1279 at the DC regional and got a higher accuracy measurement:
Our deployment arm, when it was working properly , was taking ~0.2 seconds to get the bot on the pole, so total time was ~1.27 seconds.
Below is a photo of the bot, which uses a cnc machined chassis. Our goal was to use only the minimum of materials necessary to hold the components in place. Weight came in at 2.5 lb.
Very Impressive. What type of switch are you using for the trip down?
  #207   Spotlight this post!
Unread 12-04-2011, 16:50
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Our minibot had a 3.5 second climb. Unlike a lot of robots that I saw that used magnets to hold on to the pole. Our magnets were located in our wheels and then covered in electrical tape for traction.
I have attached a picture of one of the early forms of the minibot. the magnets are underneath the thin layer of black electrical tape.
We had some problems with deployment early on, mainly due to the fact that the robot was driving down the pole, but other than that it worked reasonably well.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
  #208   Spotlight this post!
Unread 12-04-2011, 17:01
Is there any gap between the magnets, or are they butted right up against each other?
How did you secure them to the wheel?
Did you alternate them N/S ?
  #209   Spotlight this post!
Unread 12-04-2011, 17:05
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Late in the process we got a 1.7s minibot working with 1/4" tubes covered with surgical tubing. I never understood why everyone thinks magnets are necessary. If you center the minibot's mass left to right and balance the top to bottom mass difference by angling the minibot a bit, magnets are not necessary. Sure the minibot is not trying to climb straight up but it is also not trying to pull the magnets up with it - and its simpler.
  #210   Spotlight this post!
Unread 12-04-2011, 17:14
Garret's Avatar
AKA: Garret Smalley
The magnets are butted right up against eachother and are alternated. To stick them to the wheel we took electrical tape and made a loop to make it act like double-sided tape. Then we used a layer of electrical tape on top of the magnets to hold them to the wheel. Overall the minibot worked well, the main issues were silly mistakes made when hooking the battery up or when setting it up before a match (forgetting to set it to turn on). but overall when we didn't mess up before the match the minibot worked well.
7 Years of FRC
