Go to Post For example an iron block is very simple and very robust. Strap a control system on it and it will meet the requirements of being a FIRST robot. However, it sure doesn't do very much, nor is it innovative. - sanddrag [more]
Unread 13-04-2011, 22:23
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: Here's the problem with the minibot
I agree with all of the points about the end game.
However, I disagree about the necessary cost of development.
Sometime around week 2 Richard posted results of a dynomometer test of the Tetrix motors with the gearboxes removed. Using those test results it took us about 15 minutes of calculations to come up with the correct shaft size. The only motors we smoked were due to bad switch placement.
While I'm sure the above story sounds like "look how smart we are", that's not the point of sharing it. Engineering is about using calculations to come to a solution, and coming to the solution as cheaply as possible.
Message to the students: math and physics save a lot of money!!! Pay attention in school - this is why your teachers are torturing you with this stuff.
