Go to Post It's a shame that this is likely the year that sacred ground will be touched by that unworthy drive :rolleyes: - AdamHeard [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 13-04-2011, 22:36
divisionByZero0's Avatar
divisionByZero0 divisionByZero0 is offline
Hexadecimal Hacker Droid no. 0x2328
FRC #0498 (Cobra Commanders)
divisionByZero0 is an unknown quantity at this point
Exclamation Light Sabers......
How close are we to Light Saber technology? (In a non-fictional point of view)
498 Student Programmer: 2008 to 2011
498 Hemi-mentor: 2011 to ....
If all else fails, multiply both sides by zero to neutralize the equation.
Unread 13-04-2011, 23:40
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Re: Light Sabers......
far, far away??
Some serious obstacles - but I would not discourage anyone from endeavoring greatly towards a goal.
The general starting point seems to be that a light saber would be based on something like a laser - which is where one of the basic problems comes in - how to "end" the blade.
Secondly, light does not interact with light that I know of, so the "sword fight" scenes from the movies would not occur in reality.
A thought though - what if the light were just a visual indicator of the blade, but the actual "cutting force" were some other phenomenae of a shorter range nature?
Unread 14-04-2011, 00:24
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Somewhere between 10 years and never. We would have to discover and harness currently unknown physical properties of the universe to create a Star Wars light saber; and those properties might not exist (Magic 8 Ball says "Signs point to No.")
Unread 14-04-2011, 00:51
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Originally Posted by MCahoon View Post
far, far away??
Forget lasers, they will only hinder progress. Plasma is where it is at. It can be seen, shaped, and reacts similarly to light sabers in starwars. It's not technically 'light', but it works.
Again, It's called PLASMA. The 'fourth' state of matter.
Unread 14-04-2011, 07:16
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
I know what plasma is - That's not the point.
Unread 14-04-2011, 08:27
Chris is me's Avatar
AKA: Pinecone
Plasma doesn't behave as a magic semisolid beam of cutty stuff that you can turn on and off like a light saber... Sorry..
Unread 14-04-2011, 11:59
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
This definition of a light saber should be on wikipedia.
Unread 15-04-2011, 20:12
I have a slightly better belief in plasma rather than any form of light.
Unread 15-04-2011, 21:09
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Ditto Chris on plasma not being the answer. Just looking at the properties of light sabers, there's no chance any laser, plasma, etc. solution is going to work. They can effortlessly cut through people and metallic objects. Anything laser/plasma based is going to burn through things, which necessarily takes some time. And would produce a lot of smoke and byproducts. Burning through a metal without leaving a pile of slag is even harder. So yeah, give up on plasma as a solution to this. If you're going to toss out a random futury word as a solution, atleast keep up with the times and say it'll probably be something quantum.
Unread 16-04-2011, 12:30
Plasma and lasers are the closest things we have to the light saber, eventhough we've most likely discovered 10% to 30% of all the properties of both lasers and the plasma-state matter.
On a related topic:
Super-heated rods of metal of +3000 degress celcius would not be considered a safe alternate for light-sabers.
