Go to Post Part of FRC is to introduce you to how engineering is in real life: you can't use a redo card if you're landing something on the moon. - The other Gabe [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 15-04-2011, 20:28
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: 2011 Archimedes Division
Originally Posted by rtfgnow View Post
Really?
Yep.
wc 	Wayne County            Ann Arbor MI District
dt 	Detroit                 Detroit MI District
gg 	Greater Genesee         Kettering University MI District
ww 	Western Wayne           Livonia MI District
swm 	Southwest Michigan      Niles MI District
gt 	Greater Traverse        Traverse City MI District
oc 	Oakland County          Troy MI District
oc1 	Oakland County          Waterford MI District
mi 	West Michigan           West Michigan MI District
District map can be found here
Unread 15-04-2011, 20:37
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Looks awesome, this is going to be 2022's first time at championship ever, and we excited to have the dome floor Thursday/Saturday.
Unread 15-04-2011, 20:53
Refresh's Avatar
Refresh Refresh is offline
AKA: Chris
FRC #0074 (Holland C.H.A.O.S.)
Refresh has a spectacular aura aboutRefresh has a spectacular aura about
Looks like an awesome field. And we even get the saturday dome field an added bonus!
Unread 15-04-2011, 20:58
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
If the OPR rankings are from the highest of attended regionals then ours should be from OKC where are OPR should be much higher. Am I understanding that correctly?
Expect the best, Prepare for the worst
Unread 15-04-2011, 21:01
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Your OPR from Oklahoma City is 26.93 which is lower than the one listed from Kansas City.
Unread 15-04-2011, 21:06
AKA: Jon
OK, then could some one explain what factors in to OPR
Unread 15-04-2011, 21:08
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
I don't know everything, but it is based on alliance scores and not individual robot performance.
I don't know the algorithm, but it is calculated from the FMS feeds
Again, these are just arbitrary numbers...
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 15-04-2011, 21:12
The Lucas's Avatar
CaMOElot, it is a silly place
Originally Posted by Vikesrock View Post
Yep.
Good explanation, Kevin. I have a few more notes. The following 3 Event codes are artifacts of the 3 regionals in Michigan before the District System:
dt 	Detroit Regional                 Detroit MI District
mi 	West Michigan Regional           West Michigan MI District
gl	Great Lakes Regional           Michigan State Championship
These 3 prior regionals is the reason MSC has 18 qualifying spots for Championship. MSC is the only event that can ensure that some of its qualifying spots are filled by a team going to Championship. If a team that is already registered for Championship is in the top 9 of reamining point totals (after the 9 award qualifiers), that spot is then offered to the team with the next highest points in the FiM rankings (at other regionals, this unused spot is offered to the general waitlist). At least that is how I understand the 9 remaining qualifying spots based on the last few years.
Also, Waterford (OC1) is the only event code with a "1" included in it. Other event codes in the same area use a 2 (MN2, ON2, WA2). As a computer engineer, I can understand indexing arrays using starting at zero, but the inconsistency between the 4 events confuses me. MN2 (North Star) started in 09 while the rest are new this year, so Waterford should be OC2 for consistency. When you generate OPRs and use frclinks.com & twitter hashtags as much as I do, the event codes become second nature/shorthand.
Robot Inspector
Unread 15-04-2011, 21:13
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
In the end it comes down to scouting. Our score is lower than it should be in some ways. Once we actually got our robot playing properly (minus the one time when our Autonomous mode actually reversed, ran into the robot behind us, and lodged them into the rear wall), we played with extreme accuracy. Ahh well - next year we will have to go to two regionals.
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 15-04-2011, 21:22
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
OPR is a representation of an individual robots contribution to the score of their alliances. OPR is calculated using matrix algebra. This approach helps to compensate for having stronger or weaker alliance partners.
Ultimately statistics derived from final scores will always have flaws. They are a useful jumping off point, and talking point before the event, but any team worth their salt won't be considering these numbers at all for alliance selection.
Unread 15-04-2011, 21:26
AKA: Jon
Its not a big deal. I was just wondering how the OPR was calculated.
Unread 15-04-2011, 21:27
Sharp Cheddar's Avatar
Sharp Cheddar Sharp Cheddar is offline
Nathan
AKA: Nathan Becksvoort
FRC #0074 (Holland C.H.A.O.S)
Sharp Cheddar is an unknown quantity at this point
SWEET! 74 is in Archimedes!
Unread 15-04-2011, 21:34
The Lucas's Avatar
Qualification match scores and partners are the only factors. Here is my most recent explanation.
No metric based on prior matches is a replacement for good scouting of individual robots at the competition. These OPRs are calculated for single events and are not calculated across events. The best teams at weak events tend to have a inordinately high OPRs. However IMHO, OPR is better than WLT ranking, Avg score and of course bad scouting (including shout out your team numbers from the crowd). I have seen enough teams struggle through Alliance Selection that would have been much better off running OPRnet on their regional Friday night and just using that list (and hope they pick someone who has a good list based on actual good scouting)
Robot Inspector
Unread 15-04-2011, 22:10
MysterE's Avatar
FRC Team #3337
AKA: Coach Eiland
Hmm - guess that means I should nix the megaphones - and just when I was getting our round-robin 3337 down with the group. Though on a more serious note, while yelling your numbers doesn't help, I did find that gracious professionalism goes a long way in making a good impression on a top eight team.
Coach. D. Eiland
Unread 15-04-2011, 22:18
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
3467 Windham Windup is so ready for Archimedes!!!!!
1058 PVC Pirates 2016 - xxxx
