Go to Post If you see Navy ships in port, you're going to be fine. If you see ships pulling out, or no ships at all, go East. Fast. - Matt Howard [more]
Unread 12-01-2011, 16:38
madgokart madgokart is offline
FRC #1518
madgokart is an unknown quantity at this point
NanoTube Chassis
I was looking on andy mark and i saw the nano tube chassis....i was wondering what are other peoples thoughts about them?
and I was wondering how someone would go about putting bumpers around the wheels and on the nano tube Chassis?
LEGIT
Unread 12-01-2011, 16:56
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: NanoTube Chassis
i miss the old days when bumpers were recommended but not required. the drive train configurations were vastly creative and dimorphic. Unfortunately for you you would have to build some kind of mount bracket that can support a bumper out beyond the wheels
Chris is me's Avatar
AKA: Pinecone
It's not that hard. Just put some blocks no more than every 8 inches apart, between the wheels, and you're fine.
Unread 15-04-2011, 22:56
ehobel ehobel is offline
FRC #1661
ehobel is an unknown quantity at this point
On AndyMark.com it says this:
Almost New Stuff (coming soon)
C-Channel mount brackets for Toughbox Nano Tube (for mounting a outer frame)
31" Nano Tube Drive Bases.
You could mount the bumpers on the outer frame.
Unread 15-04-2011, 23:34
lturtle2996 lturtle2996 is offline
Utility Girl
AKA: Leah
FRC #2996 (Cougars Gone Wired)
Team Role: Communications
lturtle2996 is an unknown quantity at this point
We have a modified design of the nanotubes as our chassis. (We took the CAD file from AndyMark's website and made it longer, got rid of some of the holes, and had it manufactured by one of our sponsors, Vertec Tool, inc.) Personally, as a member of team 2996's drive team, I love the nano tubes. We used 6" Mecanum wheels with it, and made the gear ratio the same as our gear ratio last year when we used 8" Mecanum
Anyways, attaching the bumpers was a problem that took a lot of designing and redesigning to make possible. We ended up having supports that were perpendicular to the nanotubes that extended past the tubes to hold the bumpers. The best picture I could find to show that is this picture on the manipulator team's blog...the two metal angled aluminum things sticking past the yellow wood is what we attached it to. That and then the bottom was supported by that yellow plywood that was our electronics board!
Team 2996
Cougars Gone Wired
Colorado Springs, Colorado
2011- Regional Chairman's Award, Entrepreneurship Award
2010- Entrepreneurship Award, Excellence in Design Award, Industrial Safety Award
2009- Rookie All Star, Regional Champions (thanks 399 and 1332!), Autodesk Visualization Award, Website Award
Unread 16-04-2011, 08:42
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
We put the c-channel on the nanotubes like so and are very happy with the results.
Hi!
Unread 16-04-2011, 10:23
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
We have a design similar to AndyMark's nanotube. We lengthened the rails to 35 inches and capped them with 3x1 inch rectangular aluminum tubing 27 inches long. We have two side pieces of 3x1 tubing that are 35 inches long that attach to these forming a rectangle 27x37. The bumpers are bolted to these. We use 6" omni wheels on the corner with placation wheels in the center with a 1/16" drop. With the built in gearing we have a 12.7:1 drive ratio. The chassis is 'nuke proof' and turns on a dime.
Unread 16-04-2011, 14:02
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
the way that our cantilevered prototype supports the bumpers is cross sections of 3*3*.125 tube, an inch wide, riveted to the frame, it adds less than a pound for the whole frame.
