Go to Post In my opinion, watching someone CAD is about as exciting as watching them sleep. - DampRobot [more]
Unread 12-04-2011, 20:49
Tub Tubs Tub Tubs is offline
FRC #3049
Tub Tubs is an unknown quantity at this point
[FTC]: Inverted Wheels
Hello, i was working on getting two inverted wheels to move same direction under move a fixed distance, is their anyway i can do that
Unread 13-04-2011, 00:27
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: [FTC]: Inverted Wheels
Can you define inverted in your application? Perhaps post an image?
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 14-04-2011, 18:02
FRC #3049
Sorry, Here it is
Unread 16-04-2011, 15:50
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Hi
If your wheels are inverted, then the last digit in their motor specification should be different..
eg: 1110 and 1121
Wheel port 1, controller 1, motor 1, not inverted
Wheel Port 1, Controller 1, Motor 2, Inverted
Then telling both wheels to move 1000 counts will travel forward.
Is that what you mean?
Phil.
Phil Malone
http://www.GEARSinc.org
