Go to Post Pizza tastes best after a few long hours of robot building. - Max Lobovsky [more]
  #31   Spotlight this post!
Unread 13-04-2011, 00:26
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: pic: ummm......what?
How does the replacement look now? Look carefully for cracks and feel the smoothness of the new breaker in the places the other one failed. Not sure about your situation, but I have seen Bakelite body terminal strips give out because the mounting holes were ever-so slightly misaligned. Tightening the mounting screws for the terminal strip didn't break the strip but it did stress it so that normal usage eventually caused failure. If the mounting hardware didn't slide into place easily or wasn't perpendicular to the mounting plate, then tightening the mounting nuts may have set up internal stresses that were later released by your collision. It would be harder to develop that stress in a more flexible or more compliant base, like wood or lexan.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #32   Spotlight this post!
Unread 13-04-2011, 00:54
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
This, is why all of our electronics are secured via Zip Tie, and not solid mounting hard-wear, its faster, easier, as secure.
  #33   Spotlight this post!
Unread 13-04-2011, 13:36
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
Originally Posted by Andrew Y. View Post
eric, thanks for your point of view...but my professional experience and my advisors at work all agree my kids took the correct action by unplugging the battery...even the OSHA dude at work agrees...and him and i NEVER agree.
I dont understand the smileys. there is nothing fun or happy about safety issues such as these.
  #34   Spotlight this post!
Unread 13-04-2011, 13:38
santosh's Avatar
AKA: 2415
FRC #2415
The breaker and the cRIO are the only things that we dont have ziptied down. Im still not 100% sure it was because we got hit hard a few times. But it is definitely a possibility
  #35   Spotlight this post!
Unread 15-04-2011, 00:17
Billfred's Avatar
Billfred Billfred is offline
First it was the digital sidecar at Peachtree, now a main breaker in North Carolina.
If you guys make Einstein, I'm bringing a fire extinguisher.
  #36   Spotlight this post!
Unread 15-04-2011, 02:15
MishraArtificer's Avatar
MishraArtificer MishraArtificer is offline
Winner, Chief Delphi Insanity Award
AKA: Jeremy Marr
FRC #0240 (T.E.M.P.E.S.T.)
MishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of light
...I believe the smileys were directed at the incredible circumstance of him and the Occupational Safety and Health Administration guy actually agreeing on something.
Madness?
THIS IS F.I.R.S.T!
  #37   Spotlight this post!
Unread 15-04-2011, 19:17
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Unplugging the battery when the circuit is on carries a risk of sparks, guys. I would not suggest trying that--ANYWHERE. That's why I asked.
Don't be overly dramatic. I've seen this done hundreds of times. No problem.
The simplest way of doing things is usually the best. No need to concoct some scheme when you can just do this.
2001-2004: Team 100
2006-Present: Team 254
  #38   Spotlight this post!
Unread 16-04-2011, 17:37
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
There's little to no current being sourced while the bot is still booting up... There should also be little to no current if you're some how up close to the bot without it running around.
Those "sparks" really only fly when you're dealing with MUCH higher potentials(200 VDC++).
It's no big deal.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
  #39   Spotlight this post!
Unread 16-04-2011, 18:20
FRC #2170
You won't have to go very far into Electrical Engineering before you find out that sparks at disconnection are largely due to inductive loads, viz. motors and transformers. Inductors try to maintain current in their circuits. To do that voltage will increase across a switch as it opens and increases resistance. Eventually the switch "wins" and makes a very high resistance in the air gap, but not before a large inductor load tried to jack the voltage very much higher than usual. Sometimes the voltage spike will actually get high enough to cause current to jump the minuscule air gap as a switch opens. Result? Sparks. Not usually a good thing, so quite a bit of E.E. talent has been devoted to this solving problem.
As it applies here, if motors weren't running when you pulled the battery plug, there is very little chance of noticeable sparking. Voltages in FRC robot-land are usually quite low, so bare-skin contact is not a great danger. However, if the hand in contact has metal jewelry or tools in it, the danger of high current short circuit should not be ignored. I sometimes think that a you tube video of egregious electrician's behavior should be made to convince "kids" how easy and calamitous such short circuit "welding" can be.
  #40   Spotlight this post!
Unread 27-04-2011, 10:17
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Originally Posted by Alex Cormier View Post
Unplug the battery?
a little late, but i will comment...
I agree that there is little load when disconnecting the battery. Connecting the battery has a greater chance due to the capacitors charging the instant they are connected. soo basically we are not supposed to plug our batteries in because of spark.
@Santosh....ill see you thursday night...and we can duke it out. Selling tickets to see the fight for $450 a seat.
