Go to Post ...sitting immediately behind Chief Delphi is a bad idea. I like the team and all, but they've given me a massive headache...They've got too much spirit. - IMDWalrus [more]
  #38   Spotlight this post!
Unread 16-04-2011, 18:20
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: pic: ummm......what?
You won't have to go very far into Electrical Engineering before you find out that sparks at disconnection are largely due to inductive loads, viz. motors and transformers. Inductors try to maintain current in their circuits. To do that voltage will increase across a switch as it opens and increases resistance. Eventually the switch "wins" and makes a very high resistance in the air gap, but not before a large inductor load tried to jack the voltage very much higher than usual. Sometimes the voltage spike will actually get high enough to cause current to jump the minuscule air gap as a switch opens. Result? Sparks. Not usually a good thing, so quite a bit of E.E. talent has been devoted to this solving problem.
As it applies here, if motors weren't running when you pulled the battery plug, there is very little chance of noticeable sparking. Voltages in FRC robot-land are usually quite low, so bare-skin contact is not a great danger. However, if the hand in contact has metal jewelry or tools in it, the danger of high current short circuit should not be ignored. I sometimes think that a you tube video of egregious electrician's behavior should be made to convince "kids" how easy and calamitous such short circuit "welding" can be.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
