Go to Post Ultrasonic sensors will allow you to do fundamentally the same thing that the bump sensors do...so you can slow down and smoothly stop your robot just before it reaches the end wall, instead of running into it at full speed and then figuring out "ohh! there is a wall there!" - dlavery [more]
Unread 16-04-2011, 18:58
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
1 Second Minibot - Rampless.
https://www.facebook.com/video/video...13147&comments
Edit: if you can't view it, use this link.
http://static.ak.fbcdn.net/rsrc.php/...586213147&ev=0
This footage was taken with a high speed camera at 600fps. It's been slowed down to 60fps.
2984 will be on Archimedes. Deployment is sub 100ms.
Unread 16-04-2011, 23:33
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
Re: 1s no ramp minibot - team 2984.
Wicked fast, should make for some good competition. Just wondering, does it always fall off after hitting the top?
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
Unread 17-04-2011, 01:01
AKA: Li Pi
It tends to do that on the practice pole. On the real pole, the top pushes inwards a bit, and pushes the thing back down. It's less likely to fall off.
But we need to do testing on that.
Unread 18-04-2011, 18:26
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I would love to see the deployment system if you would like to share. Sub 100ms is very impressive for deployment.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 18-04-2011, 19:02
Re: 1 Second Minibot - Rampless.
Would you mind posting a few specs?
- weight
- wheel(shaft) diameter
- normal force
- did you measure the rolling friction?
- etc
Unread 18-04-2011, 20:27
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Any chance it would be able to make a second run if no-one had been there to catch it? I have seen several videos of super fast bots that fly off the pole once they hit the top. unless these bots are tougher than they look, I forsee dead bots all over the field, with none left by elims....
Former Mentor Team 1771
Former mentor Team 4509
Unread 19-04-2011, 03:13
AKA: Li Pi
This bot could be faster. It's meant to survive falls, and it's actually built quite heavier than it should be. It also, on an actual pole with a sprung top plate, will stay on the pole while falling downwards. The bottom of the minibot has two collapsing cylinders that act as shot absorbers for that.
Plus, we have 4 minibots, and enough C-frame to make at least 10 more at competition.
Drag was estimated, and we binary searched the shaft diameter after doing a bit of math to narrow it down to the correct spot. I'm not sure we're entirely at the optimal point.
The deployment system is two stage - predeployment pops out a tray on a turret that automatically aligns and pushes against the base. The second stage is merely a sled on rails containing the minibot, its powered by surgical tubing. It is very fast.
You can probably find a closeup in one of our matches at regionalwebcast.com during the Vegas regional.
Edit: heres an image.
deployed:
