Go to Post Doesn't make sense, Karthik. ...... You don't scare me, other than the way 1114 normally does. - EricH [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 04-15-2011, 06:32 PM
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Comming soon: 2CAN Simple Analyzing Monitor
I have made a simple java application that retrieves the status from the 2CAN. This can be launched in place of or along side of the dashboard.
To run from command line:
java <path to class file>twocansam [ip] [mode]
- - - Where IP is the ip address of the 2CAN.
- - - Where [mode] is the mode of monitoring
Example:
If the class is in a folder on the c drive called frc and the IP of the 2CAN is 10.99.99.10 with one Jaguar
java c:\frc\twocansam 10.99.99.10 T
Example Result
547 21.02 0.00 0.00 0.00 0.00 0.00 0.00 0.00
The line updates every 1 second
NOTE
The release for today will only show temperatures. I will add the other modes tonight and release tomorrow. Sunday I will add a gui so it can actually be seen with the dashboard.
Please post a reply with problems and comments
You can download on this page
http://www.satanicspider.com/frc.php
EDIT:: Haha don't mind the site, just something I was playing with a while ago!
Unread 04-16-2011, 01:11 AM
AKA: Bryant
Re: Comming soon: 2CAN Simple Analyzing Monitor
Attached first version. Host is down again ...
Unread 04-17-2011, 12:59 PM
AKA: Bryant
Update:
Added preliminary gui
Each jag appears in the window. The description (set on the 2CAN) VBus Vout Iout Firmware Version and active status is displayed
If the program thinks the jag is alive the circle and subsequent text will appear in green to give a quick visual cue. Otherwise the alive circle and subsequent text will be red.
--See image attached for overview
--New zip file added with gui. Extract all files to same folder. Run it the same as before.
Next Update:
Automatic reconnection to 2CAN if it gets disconnected
2CAN Status below jag status
Further update:
Logging?
Unread 04-17-2011, 03:08 PM
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Nice!
I would recommend changing the green text to a darker color to improve contrast.
-- Marshal Horn
Unread 04-17-2011, 04:07 PM
AKA: Bryant
Originally Posted by kamocat View Post
Nice!
Will take that into consideration. I will bold the text. May just make all the text black and have the active circle change green or red.
To launch it with your dashboard you need to go to users\public\public documents\. Make a backup of "frc ds data storage.ini" then change the cmd line to java c:\frc\twocansam 10.99.99.10 TVCB changing the variables to your needs.
Also next update:
Set monitoring to all for default if no parameters are passed
Display faults
Throw a flag if a fault occurs or if a jag disconnects
Unread 04-17-2011, 06:48 PM
AKA: Bryant
Update 0.3:
Added - auto reconnect
2CAN status - in separate window (can be closed without stopping program)
*FIXED* All text is now black and tho only color changing is the circles
All monitoring enabled if no mode parameters are passed
Displays Faults
Fault indicator (Green if no fault has occurred. Red if it has.)
Jag Communications Lost Indicator (Green if communication was constant, Red if it was lost)
That's all for tonight. Will start cracking on logging tomorrow. Let me know if there are any features I should add.
EDIT:
JUST KIDDING. Got stuck in a tight spot today and had nothing better to do. Got logging running. Gotta test when I am back at the lab. Once tested I will release 0.4
Unread 04-18-2011, 09:50 AM
AKA: Bryant
Update
Added logging
---Data appears as bar graph. Blue is normal red is if a fault is detected
---The red line is the front of the log
---Windows are shown only when that particular logging is enabled
---Example if you put B in the mode a window will pop up with v-Bus logging
---NOTE VOLTAGE IS SET TO A 24V SCALE
Added 2CAN Debug Window
---Enable it by adding a D in the mode parameter
Fixed Bug where main page would need to be open in browser
Fixed Bug where only logged data was being shown on the main window
Next Update
Menu to show/hide logging
Pause/Resume logging
Labels for scales
Ability to save logs
Unread 04-18-2011, 06:41 PM
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Since this is Java-based, will it run under any OS with a JRE?
Also, I see three dots for each motor. What do those mean?
-- Marshal Horn
Unread 04-18-2011, 09:44 PM
AKA: Bryant
Yes this should run under any os with the JRE.
The left dot signifies if the jag is seen as active
The middle dot signifies if a fault was detected (untested though)
---If at any point a fault is detected the dot will become and stay red
the right dot signifies if communications have been constant
---If at any point communications appears to have been lost the dot will become and stay red
Unread 04-19-2011, 07:59 PM
mjcoss mjcoss is offline
FRC #0303
mjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the rough
I could probably figure out how you're gathering the info from the 2CAN but ...
Any chance of getting the code? I have an android phone, the SDK, and some time between now and St. Louis and have been itching to write my first app. And this would be a cool app to have on my phone
Unread 04-20-2011, 12:22 AM
AKA: Bryant
Ill consider the release for the code shortly. The problem with going to the android phone is I do no think the same libraries are supported.
It was simple reverse engineering and parsing info. I don't see the harm with releasing the info but let me check with crosstheroadelectronics first ok?
Unread 04-20-2011, 07:39 AM
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Actually all of the information needed is contained in the open-source project located on our web site. Also a free Android apk is also available. The apk is called uCANdrive, unlike the RCS the uCANdrive is closed source.
www.crosstheroadelectronics.com
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 04-20-2011, 08:44 AM
AKA: Bryant
Well if its open source then here I go:
I pull data from ip/status.xml which contains xml with all of the individual jag data. I found it by stumbling through the index pages html for a couple of minutes.
The main XML container is a response tag
Each jag has the following tags
voltout#
current#
temp#
fault#
voltbus#
descript#
firmware#
Using the xpath library (java.xml.xpath.*) I can then retrieve the appropriate values via a simple path such as getting the voltout for jag number 7 like this
"response/voltout7" While that will work for jag number 7, i put in a loop to read all of the information from all of the jags so in reality its "response/voltout" + loop_counter but that is just logistics ...
To do it without xml and save memory you should think along this line
Open a stream over http to ip/status.xml read the response line for line looking for patterns. (eg <v* can only be 1 of 2 bits of information voltout or voltbus) find the first > character go 1 or 2 characters left to get the jag number then take the data from the right of the > character until you reach a < character
If you think it will help I will release source for 0.5 when I get it done.
BEFORE I FORGET the little problem I ran into was that the 2CAN doesn't log information unless the index page is loaded with POST data. Using the same http stream open ip/index.htm?enables=65535 and data should start rolling.
Unread 04-20-2011, 02:46 PM
FRC #0303
I downloaded the uCANdrive app about a week ago, when one of the students showed me the iPhone driver station app. It was cool to be able to drive the bot via his iPhone, although our controls are really too complicated for the interface so I went to see if there was anything similar for Android. I saw the uCANdrive and put it on my phone but it really does more than I want, and not enough of what I really want. I'll take a crack at coming up with an app that does something similar to your monitor which is really all I want. Of course I could just point my browser at the 2CAN and use the web interface but would be the fun in that.
Unread 04-23-2011, 03:07 PM
AKA: Bryant
0.5 is nearly ready I will be conducting testing today to make sure everything is in order. I want to do some cleanup of the gui first (menus appear not where menus should) then I can release.
Currently the log spits out the description then each value in the log (currently capped at 500 items updated at every 0.5 second which should amount to a bit over four minutes of log. I want to add a flag to log every 0.25 seconds which would make the logs a little over 2 minutes long. The values will be printed in order from the oldest value to the most current value. Id advise you to pause the log before saving because it will continue to log even while you have the save dialog open!
If you left click on a log it will pause it. Right click and the value at that point in time will be displayed
I also added a menu item on each log view to pause all of the values at once.
