Go to Post "It's not child labor if they wear a team shirt!" - Vermeulen [more]
Unread 17-04-2011, 19:05
klinnastruth's Avatar
klinnastruth klinnastruth is offline
Engineer
AKA: Kyle Linnastruth
klinnastruth is an unknown quantity at this point
RSS75 Banebots Motor
Our team was looking at using one of these motors for our arm, however there is no 18V on the Power distribution board. Is there any way to power it with 18V or would it cause any problems to run it though the 12V?
Unread 17-04-2011, 19:20
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: RSS75 Banebots Motor
There's been a lot of discussion on this on C/D. Go into the competition manual data for the motor curve. The motor will run fine on 12 vdc, but not produce as much power if run on 18 vdc, which is not available on the competition robot power supply.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 17-04-2011, 19:24
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Rules state that you need to power it with 12v through the PDB and a speed controller. Running a motor at a lower voltage than what it is rated for is perfectly fine, in fact that is what the speed controllers are basically doing when you turn a motor on at half power (actually a time average of 12v pulses).
Unread 17-04-2011, 19:34
Engineer
Ok thanks. We thought that would be the response, we were just trying to figure out what the torque output on the 18v motor would be at a lower voltage, which the motor curve document told us.
Unread 18-04-2011, 09:03
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Just an FYI, some RS775's were defective from the manufacturer and the case was shorted. Here's a thread with some relevant info: http://www.chiefdelphi.com/forums/sh...75+Case+Shorts
We used two 775's without any hassles, but some teams had some relatively serious issues because of defective units.
-Dustin Benedict
Unread 18-04-2011, 10:02
Chris is me's Avatar
AKA: Pinecone
If the motors weren't defective, they're great. I love them. A bit more robust than the FP or 550 and they have a pretty good punch.
But case shorts do suck, so we didn't even try to run ours in the 6 motor drive configuration we built for. We got lucky this year and didn't play any pushing matches so we were still pretty agile.
Unread 18-04-2011, 18:48
Here's a simple motor calculator which has the specs for the RS-775 built into it. You can get the performance at any voltage:
http://www.chiefdelphi.com/media/papers/2432
Unread 18-04-2011, 23:36
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
The RS-775 rocks!!!!!!!!!
I have heard the horror stories surrounding them, but as long as they are not in contact with any metal, they work excellently. 2 drove our arm this year. It was awesome.
Unread 21-04-2011, 16:44
David Dawson's Avatar
David Dawson David Dawson is offline
Capt'n turned Mentor
FRC #3771 (Yooper Troopers)
David Dawson will become famous soon enoughDavid Dawson will become famous soon enough
Same here I home they are here to stay they pack some serious power and they cant handle a stall here and there.
Unread 23-04-2011, 12:11
CNettles11's Avatar
CNettles11 CNettles11 is offline
AKA: Chris Nettles
FRC #3502 (Octo-Pi-Rates)
CNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the rough
I only have one complaint about the 775, the plate on the rear of the motor needs a little more secure attachment to the motor, but our team COULD just use a screwdriver to notch the sides of the motor. Or, we could stop using a hammer to put press fit gears on motors
