Go to Post you know you're going to meet someone important, so you put on your robotics team shirt. - NorviewsVeteran [more]
Unread 19-04-2011, 17:36
Wilzdabeast's Avatar
Wilzdabeast Wilzdabeast is offline
WilzDaBeast
FRC #0236 (Techno Ticks)
Team Role: Student
Wilzdabeast is an unknown quantity at this point
Cypress I/O Board Not Working
Hey I am trying to get our team's Cypress I/O board to work. I plugged it into the computer and programmed it using the psoc programmer, but it doesn't show up on the drivers staion, even though the cyminiprog service is running. Any help with this would be very helpful.
}-Wilzdabeast-{
Unread 19-04-2011, 17:43
Re: Cypress I/O Board Not Working
Did you use the install disk that came in the Cypress package?
It should not be installed.
That's the biggest problem teams seem to have run into with this.
The second is to verify that the correct FRC firmware has been properly installed.
If you push the small black button on the Cypress board, then the second LED should light up red (indicating Version 2 of the firmware).
