Go to Post The only thing that would finish this perfect day is a game hint... - [more]
Unread 20-04-2011, 01:15
Chris is me's Avatar
AKA: Pinecone
pic: 2791 Drivetrain Close-Up
Unread 20-04-2011, 01:17
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: pic: 2791 Drivetrain Close-Up
Its sooo clean!! But if you snap a belt or if you have to perform work on the intervals if the drive (belts ect.) how do you get in there?
Unread 20-04-2011, 01:22
R1ffSurf3r R1ffSurf3r is offline
AKA: Charlie
FRC #0233 (The Pink Team)
Team Role: Driver
R1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to behold
looks sweet and clean. we do the same thing with gears (partially) inside the box tube connecting our inner 2 wheels, and chain inside the tubing connecting them to the outer 2.
Unread 20-04-2011, 08:15
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
Very nice!
Now, if you can only do something about all that neon green tubing.....
Unread 20-04-2011, 08:25
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
There appear to be sliders on each side of the central pulley. Is it safe to assume those are to ensure the proper belt wrap?
Very Clean, this style drive is something we will be looking into this offseason.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 20-04-2011, 08:32
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
I am slightly confused I feel as if i must be missing something... how do you get enough traction between the belt and that pulley. It feels like there must be a detail not shown by this view.
Unread 20-04-2011, 08:41
nahstobor's Avatar
nahstobor nahstobor is offline
EWCP
AKA: Shan (pronounced Shawn)
FRC #2733 (Pigmice), FRC #612 (Chantilly Robotics)
nahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond repute
Looks like the mounting plate is for another motor. Were you planning for 2 FP motors in the kit?
Unread 20-04-2011, 09:16
The part of the belt shown is probably the wrap going back from end to end. There is probably belt wrap under the part of the belt you can see.
Unread 20-04-2011, 09:24
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
IIRC, the drive was designed to accommodate 2 RS775's, if 2791 saw the need for them.
-Dustin Benedict
Unread 20-04-2011, 09:50
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
I'm pretty sure it was.
Cleanest drive I've seen in a while.
Glad you've got your head on straight about axles now...
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 20-04-2011, 10:12
AKA: Pinecone
The access window you see, combined with the access at the ends of the tubes gave us enough room to thread a belt into the system and install it with about 7 minutes of work. We never had a belt failure, though.
Yes. I would highly recommend this style of drive to anyone, though using two belts instead of a serpentine belt is probably a little safer.
The picture is a bit misleading - it's a top down view of a single serpentine belt, so you can't really see how it engages the middle pulley. The bottom of the belt is wrapped around idlers to engage the pulley. The top of it (what you can see) just goes past it.
Always ensure proper belt wrap! It's super important.
We added 2 more motors when we anticipated using RS-775s in our drivetrain. A 6 motor single speed seemed cheaper than a 4 motor shifter. Then we came in 20 pounds underweight and our motors had case shorts, so we didn't really need them and pulled them off.
-Nick
At least we understand squares.
Unread 20-04-2011, 12:18
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Do you know what the gear ratio is... it looks like it was originally a CIMple box and then you have a chain changing the gear ratio again.... is this true
Thanks
Unread 20-04-2011, 12:25
AKA: Pinecone
It's designed to use the Toughbox gears. We probably should have used the CIMple Box gears, but we didn't think to.
I believe the chain reduction is 10:24, so the final reduction is something like 8.5:1.
