Go to Post That sound you hear is of every programmer in the country cringing at the thought. - Billfred [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
Unread 21-04-2011, 04:13
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: Minibot climb rate
Originally Posted by billbo911 View Post
OK, more info and a video.
Kevin,
Shifting the battery up to the top and placing some surgical tubing at the back of the battery did the trick. Now our pivot point is the farthest point from the pole. This video is taken with a fairly depleted battery.
http://www.youtube.com/watch?v=P89k0hlHd1E
Either,
More accurate measurements:
Weight is 10052g, or, 2.32 lb.
Wheel diameter is effectively .45" when compressed against the pole.
So, based on our earlier discussions, it is really close to ideal.
It seemed to me in the initial video like the plate on the top of your tower was slanted which may have caused your minibot to fly off. Its a problem we had before connecticut and then I realized that was the reason and we never had the issue again.
I don't know if you tested with a full battery or not but the battery being full would change the speed of the minibot I imagine and cause it to go slower and could be part of the fix for the minibot flying off the pole which isn't an actual fix.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
