#16
Re: 2012 Chassis Preview
I will definitely think about that. I don't even know if we will run live axles or got with the standard drive like we have done in the past.
#17
I'm a little confused as to why your bearing blocks are only on the inside, and there isn't a second mating half on the outside? The entire point of making the bearing blocks is that they can slide in a pocket to tension your chain. Without that feature there's really no reason to have them.
Additionally, once you add the radii to those pockets on the face of the bearing blocks they'll be so small they probably won't even be worth machining. |
#18
I think everyone who didn't make it to champs has the itch to start working ASAP, I know I do. But really, great CAD. Better than anyone from my team could do.
#20
Looks very nice!! but how are you going to run chain to the front wheels? Because I see you have only 1 sprocket on the center wheels.
#21
This is how our team has done Direct drive, it has worked for many many years. May I ask how you made everything so shiny.. for some reason i can't find it out. I am also designing chassis's in solidworks, but mine never have the nice colour yours are like. ![]() Good luck ! Last edited by akoscielski3 : 27-04-2011 at 22:09. |
