Go to Post This will be one of the nerdiest weekends in the history of the world. And I'm taking part in it! (yay!) - Dan Petrovic [more]
Unread 22-04-2011, 18:49
VKP's Avatar
VKP VKP is offline
VKP
AKA: Vivek Paramasivam
FRC #1899 (Saints Robotics)
VKP is an unknown quantity at this point
Re: Define Polycarbonate glue...
If a bottle of epoxy says that it can be used for "plastics," will it pass inspection as a polycarbonate glue?
Vivek
Treasurer, Senior Build Officer, Saints Robotics 1899
Seattle Olympic Regional Chairman's Award 2011
Seattle Olympic Regional Winner 2011 (Thanks 2990 & 3393)
Seattle Olympic Regional Best Website Award 2011
Unread 22-04-2011, 19:11
pfreivald's Avatar
AKA: Patrick Freivald
CD really isn't the place to ask...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 22-04-2011, 19:57
Is there a place to ask right now? Q/A is closed, and this doesn't seem like type of question to tweet the refs about.
Unread 22-04-2011, 20:07
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Define Polycarbonate glue...
Originally Posted by Brandtlamonte View Post
Could someone please use references to find whether Super glue, Epoxy, etc. Count as polycarbonate glues? I've tried but failed =/
If you go to the Loctite website, you can browse through their adhesives, and you will find what you are looking for in their descriptions of what materials they will bond. Search for the data sheet. Loctite makes many more products than "thread locker" materials. The rules do not state "marketed as" as was done with the limit switch. One formulation that I researched is called "ultra gel control". this may be suitable for your needs.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 22-04-2011, 20:09
pfreivald's Avatar
I hear ya, but it seems a little late...
Team 1551
I write books, too!
Unread 22-04-2011, 20:35
Hodge1
Print out a copy of the data sheet and show it to the inspectors when you go for inspection. You should be OK. Most of these products should be used in a well ventilated area, so don't use in the pit area. Outside application only - fumes fire hazard, etc concerns.
This is directly from the GDC:
01-31-2011, 03:40 PM
GDC
Game Design Committee
Re: Polycarbonate Glue
Any glue that is marketed as specifically for bonding polycarbonate is allowed per R92-G.
I stand corrected on my original post related to limit switches.
Sweat the details
Unread 23-04-2011, 13:05
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
Questions like, "What is polycarbonate glue?" somewhat amuse me. Maybe it's because I have had years of experience doing fabrication while kids are new to the process. So let me explain. This goes for items in the minibot list, like the allowable cements and "household light switches".
Quite specifically, if you go to a commercial supplier of sheet plastic products, on the shelf by the order counter, you will find bottles of glues called "Polycarbonate Cement" and "Acrylic Cement". Such products are what fulfill the definition as listed in the allowable parts list, just as PVC cement is what comes in the can called PVC Cement that you get in the plumbing department of the local hardware or building products store. It's that simple.
This isn't really rocket science, guys. Stop trying to make it difficult. Stop trying to run around looking for loopholes and work within the Game Design Committee limitations on construction. In the real world, those limitations are called "specifications" and they are what the customer pays you to use when you design the project you are selling them.
As a robot inspector, I'll accept any glue which specifically says in its literature that a recommended use is to glue polycarbonate, but if it isn't real polycarbonate cement, expect a big eye roll! And expect to show me that product documentation.
Dr. Bob
Unread 23-04-2011, 19:03
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Dr. Bob
Thank you.
Mentor http://www.teamtitanium.org/
Unread 23-04-2011, 21:20
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
There's at least one other special case that merits consideration: glue that is polycarbonate. Granted, that's pretty unlikely, but I know of at least a few adhesives that contain small beads for setting the bond gap. It's not inconceivable that polycarbonate could be an ingredient, making it a "polycarbonate glue". I don't think that's what the GDC intended, and I wouldn't advise trying that for new designs...but in the unlikely event that a team already used this substance, they might as well bring a datasheet listing the ingredients, and see what the inspectors think. (But be prepared to change it....)
I wonder if the GDC intended the rule to refer only to ordinary solvent-based cements (as described above), or if they considered more exotic adhesives? I also wonder whether, on balance, it would have been more useful to allow any glue used only to join polycarbonate pieces. (Wasn't sticking plastic together the core intent? I say that, because solvent cements don't really work on anything but certain plastics, so it's reasonably likely that they didn't expect teams to use the glue to attach plastic to the rest of the minibot. Of course UV-curing multipurpose adhesives designed for polycarbonate exist, and would work for that purpose.)
And as for datasheets, Loctite's are excellent; search for "Loctite [number] TDS", and you'll get a lot of good information on best practices.
For reference regarding what works (but not necessarily what's legal), this Handbook of Plastics Joining looks helpful. See table 27.9 on page 305 for some information on polycarbonate and various adhesives.
