Go to Post The real reason I am coming to IRI is to get that Paul Copioli, he will be bearhugged, if its the last thing I do :p - Mike Schroeder [more]
Unread 22-04-2011, 20:07
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Define Polycarbonate glue...
Originally Posted by Brandtlamonte View Post
Could someone please use references to find whether Super glue, Epoxy, etc. Count as polycarbonate glues? I've tried but failed =/
If you go to the Loctite website, you can browse through their adhesives, and you will find what you are looking for in their descriptions of what materials they will bond. Search for the data sheet. Loctite makes many more products than "thread locker" materials. The rules do not state "marketed as" as was done with the limit switch. One formulation that I researched is called "ultra gel control". this may be suitable for your needs.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
