Go to Post FIRST doesn't just prepare you for engineering, it prepares you for life - sciguy125 [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 24-04-2011, 00:18
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: Comming soon: 2CAN Simple Analyzing Monitor
Here is version 0.5 Still have not had the chance to test it on my rig. Anyone who wants to test it before I get the chance let me know how it goes.
See the above post for the update listing
Next Update:
Log rate switcher (1/0.5/0.25 second intervals)
Executable jar?
Aesthetics?
Please suggest features if you know of anything you would like to see!
Unread 24-04-2011, 00:21
AKA: Bryant
Originally Posted by kamocat View Post
Since this is Java-based, will it run under any OS with a JRE?
Also, I see three dots for each motor. What do those mean?
I was able to run it on *nix without issue
Once on debian and once on Ubuntu
Unread 28-04-2011, 00:31
AKA: Bryant
Version 0.6 is here and is a beta version
Updated:
---Fixed silly bug where any value between -9.99 and -0.01 would cause an exception to be thrown (values were read as - 9.99 not -9.99)
---Bundled everything into an executable jar file
---Added a batch file to start the program
---Modified the V-Out scale to show a negative throttle on the graph (note the scale will say 200 instead of 100 - will be fixed in the next release)
Installation notes:
Unpack the zip file into a folder
Modify the driverstation storage ini file:
---open the file
---copy the cmd line
--change to c:\frc\start.bat (or wherever you extracted the zip)
---Paste the command line into a new line on start.bat
**Sorry folks i dont have access to our driver station so I cannot create the line for you. If someone is kind enough to do this and post their line it would be greatly appreciated**
Other notes:
Have not had time to add the logging rate modifier like I had promised. For those without broken promises under hardship may cast the first bit (either a 1 or a 0)
Unread 28-04-2011, 01:47
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
Thanks for creating this! Our team used 2CAN for this first time this year and I think your software will be very handy for our programming subteam next year.
Trying to Help
Unread 09-08-2011, 19:16
AKA: Bryant
Anyone willing to try it out and look for bugs?
If anyone happens to have any suggestions for features let me know and I will add them before September.
