Go to Post FIRST Robotics Competition could NEVER, EVER, EVER feature aquatic robots. - dlavery [more]
Unread 18-04-2011, 20:08
msulaimain's Avatar
msulaimain msulaimain is offline
AKA: Muhammad Sulaiman
FRC #3346 ([{Kamikaze Komets}])
msulaimain can only hope to improve
Send a message via AIM to msulaimain Send a message via Yahoo to msulaimain
Re: Deploying Code Shortcut
Originally Posted by Cecil View Post
or.. you can take the easy way. Download FileZilla and use the simple drag and drop method to move the files..
I have been using FileZilla for like forever. It is the way to go. It's basically a organized/program that is very similar to the way that is expressed above.
int main()
::::::::: include=>commitment;
::::::::: int=>school name=>Asheboro::High
::::::::: int=>team name=>Kamikaze::Komets;
::::::::: Priority_Queue=>FRC Championship::2012;
::::::::: Max_Element=>Teamwork;
Unread 18-04-2011, 23:48
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
The download tool in Workbench uses FTP. All it does is automate the process for you. It should be no slower or faster than FileZilla or any other FTP client.
HTH
Unread 23-04-2011, 19:09
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
hm
is there another way to do this besides being connected to Port 1 on the Crio, like using the bridge or port 2?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 24-04-2011, 01:37
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Originally Posted by Mk.32 View Post
hm
All that is required is for the robot (the FTP server) to have a IP path to the FTP client. The physical path does not matter, only that a logical path exists. It can definitely go through the bridge but am not sure about cRio port #2. The FTP server on the robot might be listening on port 2 (it certainly is capable of it) but I've never tested this configuration.
HTH
Unread 24-04-2011, 14:35
Mk.32's Avatar
AKA: Mark
HTH
Recently I tried that however was unable to get it to work with the IP, 10.36.47.2 (our team number) however using Port 1 with the same IP works fine. And Suggestions on what ip? or is there some router config we need to do?
Unread 24-04-2011, 18:54
The second IP port is normally configured to 192.168.0.xxx. It can be changed via Max, but I suspect that the imaging tool will put it back. I'm not sure if an ftp server is active on the port. I suspect it can be configured if needed.
Greg McKaskle
Unread 24-04-2011, 22:54
Zach O's Avatar
Zach O Zach O is offline
Building an iOS app @ glacial speed
AKA: @FRCZach
Zach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond repute
Our team has actually set up a sweet system for autonomous that concurs the task of not having to deploy code.
Our autonomous code actually parses an text file found on the robot that we transfer using FTP. This makes for a quick and easy way to change autonomous' and helps to avoid touching or changing code on the robot, that might affect our teleop code.
We determined we can change our autonomous code from one to another in 11 seconds.
Follow me twitter dot com slash frc zach
Unread 24-04-2011, 23:47
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
You need to have the ftp client on the same subnet. Port 2 is on subnet 192.200.0.0 I think. Access the console on the robot and type 'ifconfig' or 'ifShow'. That will tell you the IP address of the robot on both port 1 and 2. So if the robot is 192.200.0.1, use 192.200.0.100 or the computer running the ftp client program.
HTH
Unread 25-04-2011, 00:05
Mk.32's Avatar
AKA: Mark
ah that makes since, quick question how do you access the console on the robot?
Unread 25-04-2011, 01:22
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Get a copy of the GettingStartedWithC.pdf file from the WPI web site. It explains how to setup a debugging session with the robot. With the debugging session working, right click on the target server (in the remote systems dialog), choose "Target Tools' then 'Target Console'.
Plus I think you can telnet directly to the robot (debugging session or not) if you checked the 'Enable NetConsole' check box from the cRIO Imaging Tool applet. (not 100% sure about this, no robot to check it out on). You can telnet from any Windows command line, just issue the command 'telnet 10.12.96.2' (for our robot).
HTH
Unread 25-04-2011, 02:09
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
HTH
Just something to note: Windows 7 has telnet functionality disabled by default. To enable it, go into Control Panel, click the category "Programs", and click "Turn Windows Features on or off". A smaller window should open up with a series of options. Search down the list for "Telnet Client" and check the checkbox to the left of it then click "ok".
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
