Go to Post "I'd like the teeter-totter..." - Billfred [more]
Unread 04-03-2011, 12:46
Nelson's Avatar
Nelson Nelson is offline
Lord of Engineering
AKA: Spock
FRC #3241 (Dragon Army)
Nelson is an unknown quantity at this point
Re: Losing Jaguars? What are the common reasons why it burns out?
Ironicaly, we broke just about every peice of equipment last year, including a battery, and although we had a jaguar that we though was broken, it ended up being the transmissin, so it appears our team has luck with jaguars, if not with everything else.
Unread 04-03-2011, 13:02
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
My Quation ToTexas Instrument!
Who we can know if the Jaguar is working or Not?
Is there any way to do that without any Guess?
TEAM 1946-Tamra
Unread 04-03-2011, 13:30
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Originally Posted by martin417 View Post
We did have several stop responding while being addressed for CAN, but we were able to recover them using the recovery utility.
My recommendation: When addressing jags, do not try to address a whole string at once. For gray jags, use a black jag as the converter and only connect one gray jag at a time. For black jags, connect directly to one and only one black jag.
Yeah... sorry about that.
I was updating the firmware on all of them, and they were all daisy chained together. Never had a problem with it before...
Spent a good hour and a half trying to figure out the problem too. :/
Unread 08-03-2011, 12:56
bensherman's Avatar
bensherman bensherman is offline
AKA: Ben Sherman
FRC #1676 (The Pascack Pi-oneers)
Team Role: Electrical
bensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of light
We lost a total of 4 black jags this season. It seems that the beige jags are much more reliable. They're all connected via PWM's not CAN, so the CAN issue above can be ruled out. We lost two during competition for seemingly no reason, they just stopped. We're going to get the 2011 jag's replaced and swap our flight bot out with the older model jags as they haven't given us issues.
2011 NJ Regional #1 seed, winner
2011 Virginia Regional winner
2010 New Jersey Regional Winner
2010 Virginia Regional Winner (15-0 )
2010 Curie Finalists
Editor - alltechdaily.com
Unread 18-03-2011, 13:48
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
As said by ben, we have lost a lot of black jags. i took one or two them apart to try and figure out why the kept burning out. It looked like the electronic valves (i think that's what they're called. its the 8 boxes around the central capacitor) actually melted the plastic encasing holding the in place. One of the mentors on the team told me that that usually happens when the source, gate, and drain components inside the valves get knocked out of place, which messes up the flow of electricity
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
Unread 18-03-2011, 14:13
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
We've lost 1 black Jaguar so far.
The reason for the failure isn't clear...but there were enough possible causes that it may not have mattered.
It refused to power on shortly after it rained and water got near it (but not inside it).
It refused to power on shortly after the robot it was on was hauled by truck to a practice area. So if there was some junk inside it...it had all the opportunity it needed to cause trouble.
We got no life...at all...from it once it failed and it failed from the instant of power on (so it basically just never turned on again).
A close inspection inside the unit did not demonstrate the cause.
We simply replaced it and we were fine.
Unread 18-03-2011, 16:21
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
We use the tan Jags on "J-Bot", the square defense bot we practice with. We were using the 2009 wheels and traction was pretty terrible on carpet. Eventually so much static built up that when the left side of the robot hit a metal pole it discharged and the left Jag died.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 09-04-2011, 19:00
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
We've had very bad experiences with Jaguars, to the point that we absolutely refuse to use them. The fact that we had switched to mecanum drive this build season, and that the new black Jaguars had been released encouraged us to try our hands at CAN once more (our first experiment with it had been in '09, with 2CAN, but the Jaguar we played with failed straight out of the KoP, and was enough to warn us away from them).
We ended up spending the first 4 weeks of build season incessantly debugging persistent, temperamental CAN issues. An order of 15 blacks came in during week 2, only for us to begin CAN configuration and discover that 3 were dead out of the box. Another four failed upon connecting them to a drivetrain. Subsequent horrors include intermittent communication, a Jaguar that would work when it was the only one in the CAN and became a coupler when placed in a CAN with more than one Jaguar, Jaguars that continuously encountered voltage faults (despite no gearbox jamming or whatnot), and one with exploding blue sparks. After that, we just refused to continue with Jaguars.
Jaguars on PWM on the other hand, seem to be effective motor controllers (our clone robot this year - since it was our first try at mecanum - has Jaguars on the drivetrain, and they behave just fine).
We always cover up the electronics board when drilling, and vacuum for shavings after doing so (while grounding the robot chassis).
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 09-04-2011, 21:43
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
However, Sam, I wouldn't discredit metal shavings and static. Mounting to an exposed metal plate, over which we basically machined our robot, probably caused a lot of problems. I love blaming programmers, too - have we tried to look at other teams' codes? There are teams that do jags without a hitch. We're doing something wrong.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 09-04-2011, 22:56
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
At LA we lost 2 or 3 Jags. I don't remember the colors I know that at least 1 was black.
Later, we took them apart and found metal shavings inside the cases. They were probably the cause of the failure.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 26-04-2011, 00:28
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
Metal shavings can kill a jaguar fast!, Ways to prevent it are clean up after cutting and shield the motors while doing work on another part. But sometimes they just combust and one of the terminals can be faulty.( That's what happened to one of our brown jags.) Just have to take precautions with them due to the failure rate.
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 26-04-2011, 06:47
yara92's Avatar
AKA: Mohamed
we lost 2 or 3 Jags. The reason we figure that we are not be carefully when our guys working drilling metal shavings See picture.
I open all the Jaguars clean them by ear. They worked fine
Mentor team 1946
http://www.chiefdelphi.com/forums/at...d=13038147 79
TEAM 1946-Tamra
